JanicefromAtlantis
/ JanicefromAtlantis #1
JanicefromAtlantis
John Deere 955
How to remove 70A front bucket from john deere 955
/ JanicefromAtlantis #2
Janice
You would get more response if this was in the John Deere section. Other option google search for deere 955 with 70A loader. I found a couple videos showing how to detach.
/ JanicefromAtlantis #3
Janice
I moved it to the JD forums with a redirect that will expire in a month. ;)
/ JanicefromAtlantis #5
Welcome to TBN Janice...enjoy.
/ JanicefromAtlantis #6
There are 4 pins (2 on either side) held in by C-clips. Use a vice grips or flat screwdriver to pull one out on either side of each of the pins. Then take a round rod or 'drift' and pound the pins out. Remove the pins when the bucket is flat on the ground in a resting position (based on relaxed hydraulic lever control).
FYI: Same as an 80A loader. I bought the JD Hook & Pin quick attach hinged brackets that fit on my loader and now have forks, bucket, snowplow, posthole digger, & snow pusher attachments to play with. Forks are now the most popular item at my place !
3ft 5-Pointed Star Metal Decorative Sign (A66738)
3ft 5-Pointed Star...
2005 PETERBILT 379 (A67714)
2005 PETERBILT 379...
2014 CATERPILLAR 320EL RR EXCAVATOR (A65056)
2014 CATERPILLAR...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A64553)
2025 HT360W Mini...
2022 WEILER S450 SKIDDER (A65056)
2022 WEILER S450...
2008 WINSTON AP22024AL-DC EQUIPMENT TRAILER (A66091)
2008 WINSTON...
