JanicefromAtlantis
/ JanicefromAtlantis #1
JanicefromAtlantis
John Deere 955
How to remove 70A front bucket from john deere 955
/ JanicefromAtlantis #2
Janice
You would get more response if this was in the John Deere section. Other option google search for deere 955 with 70A loader. I found a couple videos showing how to detach.
/ JanicefromAtlantis #3
Janice
I moved it to the JD forums with a redirect that will expire in a month. ;)
/ JanicefromAtlantis #5
Welcome to TBN Janice...enjoy.
/ JanicefromAtlantis #6
There are 4 pins (2 on either side) held in by C-clips. Use a vice grips or flat screwdriver to pull one out on either side of each of the pins. Then take a round rod or 'drift' and pound the pins out. Remove the pins when the bucket is flat on the ground in a resting position (based on relaxed hydraulic lever control).
FYI: Same as an 80A loader. I bought the JD Hook & Pin quick attach hinged brackets that fit on my loader and now have forks, bucket, snowplow, posthole digger, & snow pusher attachments to play with. Forks are now the most popular item at my place !
PALLET OF HOSE REELS (A67714)
PALLET OF HOSE...
2013 CATERPILLAR 259B3 SKID STEER (A65056)
2013 CATERPILLAR...
DEUTZ FAHR 4080E TRACTOR (A65057)
DEUTZ FAHR 4080E...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
1987 Fruehauf MC 307 Insulated 7,500 Gallon T/A Chemical Tanker Trailer (A68183)
1987 Fruehauf MC...
CAT 930 60" Forks (A68134)
CAT 930 60" Forks...
