JanicefromAtlantis
/ JanicefromAtlantis #1
JanicefromAtlantis
John Deere 955
How to remove 70A front bucket from john deere 955
/ JanicefromAtlantis #2
Janice
You would get more response if this was in the John Deere section. Other option google search for deere 955 with 70A loader. I found a couple videos showing how to detach.
/ JanicefromAtlantis #3
Janice
I moved it to the JD forums with a redirect that will expire in a month. ;)
/ JanicefromAtlantis #5
Welcome to TBN Janice...enjoy.
/ JanicefromAtlantis #6
There are 4 pins (2 on either side) held in by C-clips. Use a vice grips or flat screwdriver to pull one out on either side of each of the pins. Then take a round rod or 'drift' and pound the pins out. Remove the pins when the bucket is flat on the ground in a resting position (based on relaxed hydraulic lever control).
FYI: Same as an 80A loader. I bought the JD Hook & Pin quick attach hinged brackets that fit on my loader and now have forks, bucket, snowplow, posthole digger, & snow pusher attachments to play with. Forks are now the most popular item at my place !
CAT 416F Front Loader Bucket (A68134)
CAT 416F Front...
2005 INTERNATIONAL (INOPERABLE) DURASTAR 4300 (A67714)
2005 INTERNATIONAL...
2015 CHEVROLET CAPRICE POLICE VEHICLE (A66091)
2015 CHEVROLET...
CHECO GREASE UNIT (A67714)
CHECO GREASE UNIT...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2022 CATERPILLAR 259D3 SKID STEER (A65056)
2022 CATERPILLAR...
