JanicefromAtlantis
   / JanicefromAtlantis #1
JanicefromAtlantis
John Deere 955
How to remove 70A front bucket from john deere 955
   / JanicefromAtlantis #2
Janice
You would get more response if this was in the John Deere section. Other option google search for deere 955 with 70A loader. I found a couple videos showing how to detach.
   / JanicefromAtlantis #3
Janice
I moved it to the JD forums with a redirect that will expire in a month. ;)
   / JanicefromAtlantis #5
Welcome to TBN Janice...enjoy.
   / JanicefromAtlantis #6
There are 4 pins (2 on either side) held in by C-clips. Use a vice grips or flat screwdriver to pull one out on either side of each of the pins. Then take a round rod or 'drift' and pound the pins out. Remove the pins when the bucket is flat on the ground in a resting position (based on relaxed hydraulic lever control).
FYI: Same as an 80A loader. I bought the JD Hook & Pin quick attach hinged brackets that fit on my loader and now have forks, bucket, snowplow, posthole digger, & snow pusher attachments to play with. Forks are now the most popular item at my place !
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
2012 Kubota M108S (A50123)
2012 Kubota M108S...
UNUSED X-STAR 101" X 25' BRIDGE PLATFORM (A51247)
UNUSED X-STAR 101"...
