laurencen
- Joined
- Feb 19, 2007
- Messages
- 1,211
- Location
- saskatchewan Canada
- Tractor
- Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
have a Jacobson HR5111 mower, been good but last night had steering issues, noticed when turning the steering the actual wheels will be unresponsive more so if not moving, it still turns when mowing but sluggish and soft, first thing comes to mind several years had a similar issue turned out to be the plate the cylinder connects to and both tie rods cracked only moving one wheel, in this case both wheels are affected, shop manual gives little options other than something is seized but jacked it up and its fine.
Im leading towards the steering cylinder piston seal is bad, odd it got worse after a few hours when running hotter than normal due to the load cutting tall grass and plus 35C outside.
before I pull the cylinder off and other ideas would be appreciated
