j.i. case 1949 SC
/ j.i. case 1949 SC
i also made a mistake and filled up my ford 8n tractor with 10-20 extreame hydralic oil not nowing that the book called for 90 weight in her wich is **** expesive 21 dollars a gallon i got the 90 weight for my Case tractor cuz its a alot nicer tractor do you think i will do any extreame damage to ford if i just use to push snow and do a lil brush hoggin? and what kind of equipment do you think my case tractor can handle? bailer?
/ j.i. case 1949 SC #22
hyd oil in that ford will wear out the rear end and tranny..
you could go with a utf fluid.. or a yellow metal safe gear oil.
napa sells 90wt gl1 5g pail for about 50$ 65-205
plenty of people sell a 80w90 gl4/5 mt1 yellow metal safe gear oil too.. again.. about 50$ a pail.
utf from 20-50$ a pail will be safe too.
not r&0, jack oil, or plain hyd oil.. or atf fluid.
i don't hay.. so am unsure what bailer you could run. as for mower.. figure on average.. 5 pto hp per foot of mower. that's average. go slow and go a lil wider.. if in heavy.. go shorter.. etc.. or take less bite..
soundguy
/ j.i. case 1949 SC #23
The Case can power a baler like a John Deere 14 or 24t. You can pull a 2 or 3 bottom plow, run a 8 foot sickle mower ext. The tractor has the weight to do most things people use 40hp tractors today for.
/ j.i. case 1949 SC
what would be the best mower for hay on it?
/ j.i. case 1949 SC
im going to leave the tractor sit outside anything i should make sure i do or cover up on it? it should not hurt it to put ford gear oil 90 weight in the rear end shuld it the book just calls for 90 weight oil is all and thats all tsc has
/ j.i. case 1949 SC #26
Cover up the exhaust unless you want water to get in it and seize your engine. Make sure that the rubber grommet around the shifter is there and intact or water can get into the transmission. The 90 weight oil won't hurt it one bit.
/ j.i. case 1949 SC
Ok do i need to cover up the distributor cap at all?
/ j.i. case 1949 SC
i decieded it was smarter to put the 8n ford outside and the case in the shed much better machine to nice to sit outside in my book it does not tell me were the drain plugs are for the rear end im guessin its the big pipe plug on the right hand side up by the front and then theirs a smaller pipe plug underneath the rear in the middle near the hitch correct i no were the clutch drain and oil drains are
/ j.i. case 1949 SC #30
you can spary silicone onthe dizzy cap to help it shed water.
the gear oil fo rhte ford will be fine.. but probably cheaper to get generic gear oil..e tc..
/ j.i. case 1949 SC
/ j.i. case 1949 SC
also i read in the book about condesation build up it says to undo the oil screen at the bottom untile their just a few threads left and the water will come out is that sumthing i really need to worry about?
/ j.i. case 1949 SC #33
I think that you found the drain plugs alright. How is your oil pressure? I would only worry about condensation if it looked as through the metal was starting to sweat. By loosening the plug to the last thread the water that is on the bottom will drain out. I have a friend who does this all the time on his International as coolant leaks into the oil pan.
/ j.i. case 1949 SC #34
I'm not sure if the SC is the same setup as the VAC on oil pressure.. but I was initially worried about the 15 psi oil pressure.. till i actually rread the oem manual and it states that 15 psi is book/normal oil pressure.. :)
/ j.i. case 1949 SC #35
I have 20psi on my Sc. It worried me to until i read the dealership manual and discovered that new they had 30psi and 20psi is above average pressure.
/ j.i. case 1949 SC #36
i think they use a high volume / low pressure, flow system.
/ j.i. case 1949 SC
my oil pressure is at 20
/ j.i. case 1949 SC #38
plenty
/ j.i. case 1949 SC
also i have a some form of hydralic hook up in the back now i dont have the eagle hitch so what all can i do with this mike?
/ j.i. case 1949 SC #40
It is probably the hydraulic outlets hooked up to a homemade lift If I understand you correctly. I am not that familiar with the hydraulics on these machines as mine is a 45 model the year before the hydraulics came out on them.
Could you post some pictures of the tractor to help us see what you are talking about as equipment does get farmerized over the years.
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
Ford 2000 Tractor (A65579)
Ford 2000 Tractor...
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
2017 International HX620 Quint Dump (A62613)
2017 International...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
