J.D. 950 FLOODING 1510 TRANS
   / J.D. 950 FLOODING 1510 TRANS #1
SWINNEY
HELLO IHAVE A 950 JD YANMAR ENGINE THAT FLOODS LIKE ITS GETTING TO MUCH FUEL. I TOOK THE INTAKE AND EXHAUST OFF STILL WILL DO IT SOMETIME AFTER IT GETS WARM. ANY HELP THANKS ALSO I NEED A TRANS FOR A 1510 POWER SHIFT THANKS IN ADVANCE J.R. SWINNEY
   / J.D. 950 FLOODING 1510 TRANS #2
Hi Swinney
I have 2 yanmar 1510 transmissions in stock
Please call if interested
ernie@molalla.net
503-829-9170
   / J.D. 950 FLOODING 1510 TRANS #3
Swinney,
It sounds like you have sticky injectors, go to auto parts & get some 911 injection cleaner & try that. If that don't work you may have to get different injectors or have them rebuilt. I have a set of new ones for $200.00 + shipping if interested
Yanmarmarv
   / J.D. 950 FLOODING 1510 TRANS #4
What is your indication of flooding? Could it be poor combustion due to low compression?
I HAD THE INJECTORS TESTED AND CLEANED. THE FLOODING PROBLEM IS MORE LIKE IT STARTS CHOKING AND IT WILL BLOW TREMENDOUS AMOUNTS OF BLACK SMOKE THEN DIE AND TAKES A LONG TO START SOMETIME IT WILL RUN A HOUR OR SO BEFORE IT DOES THIS .IT ONLY HAS 641 HOURS AND I CAN TELL. I HAVE HAD SEVERAL MAYBE 6OR SO . ICUT MY GRASS DURING THE AND WHEN MY GRASS DIES IN OCT. I SELL IT.NEVER HAD ONE DO THIS UNLESS THE AIR CLEANER WAS STOPPED UP. ANY OTHER HELP? THANKS J.R. SWINNEY
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
2025 Nationcraft 8.5X36TTA3 38ft Tri-Axle Enclosed Trailer (A59231)
2025 Nationcraft...
Sakai SV505 (A60462)
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
5ft Rotary Brush Cutter Tractor Attachment (A59228)
5ft Rotary Brush...
2019 CATERPILLAR 336 EXCAVATOR (A60429)
2019 CATERPILLAR...
