I've got some big news!
/ I've got some big news! #1
shawnrogan
Patterson, New York
Kioti CK30
I\'ve got some big news!
I've got some big news, the parts finally came through, and I'm holdin the keys to a brand new CK30. Have you been outside, sure is a nice night, how about a little test drive down by the lake? There's a place I know about, where the dirt road runs out, we can try out the 4wd. Cmon now what do you say, girl I can hardely wait- TO GET A LITTLE MUD ON THE TIRES!!
My ck30 TLB arrived last night courtesy of Rick and Amy @ Wallace Tractor. Have not had a chance to even read the manual, but am looking forward to a weekend of figuring it out.
Thank you to all the TBN folks who gave me their advice, it lead to my descision and to my dealer. This site rocks!
I'll post pic's shortly, but here's what I got
CK30 gear with 18" backhoe, 60 " loader
Canopy, 4 worklights, brush guard, 3 hooks welded to loader bucket (2 cinch, 1 slip) /forums/images/graemlins/smile.gif
Looking forward to many projects and many years of quality Kioti ownership.
/ I've got some big news! #2
Re: I\'ve got some big news!
Sounds good Shawn, best of luck to you and your new tractor. I like the looks of the Kioti's.
/ I've got some big news! #3
I'm jealous........ /forums/images/graemlins/frown.gif Starting to get a little impatient with my Kioti order! Yours is nicely rigged, your fix'in to have a great time, Enjoy!
/ I've got some big news! #4
Congratulations!!! You are gonna love it. Now go have some fun....oops I mean go get some work done. /forums/images/graemlins/smirk.gif
/ I've got some big news! #5
Well grab that camera, you know we gotta have pictures. Congratulations
Steve
/ I've got some big news! #6
So you bought a new CK30. Who cares? WE DO! Congratulations. Sounds like you got enough equip. to keep you very busy for a little while, and when the "thrill" starts to rub off, you'll be out buying more implements.
John
Got a few hours on the new machine over the weekend, dug out my first small stump- tougher than I thought it would be. But of course I'm learning the controls. Moved some rocks that have been in my way for 4 years- AMAZING what the CK30 can move. I easily moved stones that the backhoe could not lift. What is the optimal engine rpm for the hydraulics?? I've only been running at 1500 rpms thus fa,r, and don't plan to run any higher until I get many more hours on her. Going to definetly fabricate a thumb for the BH because I've got a lot of stone to move and walls to rebuild. Also got a second hand York rake that I've been dying to pull up and down my 1/2 mile gravel driveway. Can't wait to get some seat time!!
/ I've got some big news! #8
</font><font color="blue" class="small">( I've only been running at 1500 rpms thus fa,r, and don't plan to run any higher until I get many more hours on her. )</font>
There's no reason to run at such low RPM, as a matter of fact, that's low enough that you'll be lugging the engine down a good bit when you're doing any serious work. I recommend that you run it as you're going to later on. Using the backhoe should be good around 1800-2200 being careful on the swing as that seems to be the fastest movement you'll have.
If you're going to run a PTO implement, go ahead and run at the 540 mark.
It's much more damaging in the break in period to lug the tractor down a lot than running at higher speeds. Doing heavy duty work at low RPM is probably not the best way.
Most posters seem to favor simply using the tractor as you will always use it, but as I said, just don't lug the engine down. You won't hurt it, and the engine parts will meld just fine in the first 50 hours. Then follow the service schedule and change all the fluids and filters.
One good thing is to always warm the tractor for at least 5 minutes before you start working it. In cold weather, up that appropriately, and make sure you don't use the hydraulics until they're warmed good as the viscosity will be too thick until it's warmed. That can damage the pump.
I wish you great tractoring. You have a wonderful tractor.
John
/ I've got some big news! #9
In my opinion, you're doing a lot more harm than good. Like KiotiJohn said, speed that thing up. You are NOT going to hurt it running it at PTO speed; just vary the RPM pretty frequently.
/ I've got some big news! #10
Congratulations Shawn, Like John said, dont be afraid to turn up the rpms.. Also get youself a toothbar, it will make your stump removal alot easier.. Also just a tip, if you plan on small tree removal, push the tress over with your loader instead of cutting them down with a chainsaw,, the whole root ball will come out for you and you save alot of time.. Matt
Thanks for all the input, I'll definetly run the rpm's higher. I was going to order a toothbar from Markham welding, just waiting for a little extra $$. By the way, I came across a deal to good to pass up. Found a guy selling two Meyers 7' snow plows. One with hydraulics and one without. After talking with him I realized he did not want to sell them seperately but wanted to get rid of both of them. Both in great shape! Anyone in the NY, PA, CT area want to buy a plow for their tractor? Let me know. One is going to look great painted Kioti orange!
/ I've got some big news! #12
Yeah, speed 'er up- consider top rpm on your diesel is just off- idle on a gas burner. Varying rpm and some decelerating/ compression braking is the most recommended maneuvers in most 4 stroke break in procedures, by leading manufacturers and remanufacturers.
You may want a magnetic tip drain plug for the "ultimate" in maintenance. NAPA may be able to match the threads. And some diesel fuel lubricity/ conditioner for valve lube and to help prevent hammering the seats and lube pump and injectors is on the top of my list for longevity/ cleanliness.
Low sulfur diesel fuel actually strips lubrication from critical injection surfaces.
Regards Mark H.
Certified ASE Master Automobile Tech.
Certified ASE Advanced Engine Performance
/ I've got some big news! #13
Oh, and buy your wife some roses if she let you get that fine machine!!
Favorite quote of a redneck tractor owner: "I told my wife I loved her when I married 'er and told her I'd let her know if I ever changed my mind"
ps: best spoken with a thick deep south accent, and for effect a big belly and a short tie completes the package...
just a joke guys!!!
/ I've got some big news! #14
</font><font color="blue" class="small">( You may want a magnetic tip drain plug for the "ultimate" in maintenance. )</font>
Your tractor, and Shawn's both come with magnetic tipped drain plugs! I was pleased to note that mine had only a small amount of filings on it at the 50 hours change, and virtually none at 300 hours when I decided to change out the fluid early.
John
2014 KENWORTH T370 ROAD TRACTOR (A62130)
2014 KENWORTH T370...
New/Unused AGT Industrial Gas-Powered Air Compressor (A61166)
New/Unused AGT...
New/Unused 3 in 1 Bucket for Mini Skid Steer (A61166)
New/Unused 3 in 1...
BUNDLE OF 4"X RANDOM LENGTHS RED OAK FLOORING (A62131)
BUNDLE OF 4"X...
2012 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A61568)
2012 Mack CHU613...
FRONTIER RC2060-60" ROTARY MOWER (A62130)
FRONTIER...
