Comparison It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K?
   / It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K? #1
countryguy1225
Fenton, Mi
Kubota M6060 & L2550GST(4wd), W/ Backhoe attch. Mitsubhish MT160D (4wd) :- )
Finally going to take on a new Kubota! Between the M5660 or the M6060- It'll compliment our 91 L2550GST4WD w/ turfs. but I'm confused on any differences beyond HP from the M5660 to the M6060? Putting the R4's on her. FEL w/HD bucket, and a set of forks.
Anyone know if there are some diff's in the two that will sway us up the 2K?
Thanks in advance!
   / It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K? #2
The two big differences are M6060 - 2WD Wheelbase: 84.4 inches [214 cm] & 4WD Wheelbase: 83.1 inches [211 cm],
and Weight: 5005 to 5358 pounds, 3pt Control: position control and top-link draft sensing and available Cab.
vs
M5660 - 2WD Wheelbase: 82 inches [208 cm] & 4WD Wheelbase: 83.1 inches [211 cm] and Weight: 4189 to 4387 pounds, 3pt Control: position control
I see the 6060 has the deluxe seat w/ arm rests also. Thanks! I noticed some little diff's in the Operators station. I need to check the remotes. 5660 has 1 rear standard. Wonder if there was something more. Going to see a couple soon. Just wondered if there was some wow item I missed.
   / It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K? #4
   / It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K? #5
Thanks in advance!
Assuming that you are speaking of the M5660SU.
FWIW, SU stands for Special Utility, which translates into stripper. Correspondingly, it is a cost reduced model.
Aside from convenience/comfort features and a bit over 600 lbs., the most significant difference is the engine.
The 5660 uses the 148.5 CI engine used in the L6060, derated a couple of HP to 50 PTO HP. The 6060 uses the 203 CI engine used in the 7060 derated about 8 HP to 56 PTO HP.
It would certainly pay considerably more than $2,000 more for the 6060 as compared to the 5660.
SDT
   / It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K? #6
Keep in mind the M6060 is cheaper than the L6060. At least when I priced them last year. They are proud of the HST+ transmission!
   / It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K? #7
think the 12 speed only availabe in 7060. that option get you 16gpm hydraulics and epto
   / It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K? #8
think the 12 speed only available in 7060. that option get you 16gpm hydraulics and epto
That is correct. I just went through this criteria when selecting my 7060 and I did buy the 12 spd.
   / It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K? #9
I did this wrong. 8-speed seemed like enough until I got it home. Now I have the rest of my life to regret my choice because, for my uses and cheap nature, I am not going to take a Mulligan on it.
   / It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K? #10
and Weight: 5005 to 5358 pounds, 3pt Control: position control and top-link draft sensing and available Cab .
vs
Unless it has changed from the previous 40 series you have to step up to the M7060 for a factory cab
Utility Cart (A59228)
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
