Comparison It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K?
   / It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K? #1
countryguy1225
Fenton, Mi
Kubota M6060 & L2550GST(4wd), W/ Backhoe attch. Mitsubhish MT160D (4wd) :- )
Finally going to take on a new Kubota! Between the M5660 or the M6060- It'll compliment our 91 L2550GST4WD w/ turfs. but I'm confused on any differences beyond HP from the M5660 to the M6060? Putting the R4's on her. FEL w/HD bucket, and a set of forks.
Anyone know if there are some diff's in the two that will sway us up the 2K?
Thanks in advance!
   / It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K? #2
The two big differences are M6060 - 2WD Wheelbase: 84.4 inches [214 cm] & 4WD Wheelbase: 83.1 inches [211 cm],
and Weight: 5005 to 5358 pounds, 3pt Control: position control and top-link draft sensing and available Cab.
vs
M5660 - 2WD Wheelbase: 82 inches [208 cm] & 4WD Wheelbase: 83.1 inches [211 cm] and Weight: 4189 to 4387 pounds, 3pt Control: position control
I see the 6060 has the deluxe seat w/ arm rests also. Thanks! I noticed some little diff's in the Operators station. I need to check the remotes. 5660 has 1 rear standard. Wonder if there was something more. Going to see a couple soon. Just wondered if there was some wow item I missed.
   / It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K? #4
   / It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K? #5
Thanks in advance!
Assuming that you are speaking of the M5660SU.
FWIW, SU stands for Special Utility, which translates into stripper. Correspondingly, it is a cost reduced model.
Aside from convenience/comfort features and a bit over 600 lbs., the most significant difference is the engine.
The 5660 uses the 148.5 CI engine used in the L6060, derated a couple of HP to 50 PTO HP. The 6060 uses the 203 CI engine used in the 7060 derated about 8 HP to 56 PTO HP.
It would certainly pay considerably more than $2,000 more for the 6060 as compared to the 5660.
SDT
   / It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K? #6
Keep in mind the M6060 is cheaper than the L6060. At least when I priced them last year. They are proud of the HST+ transmission!
   / It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K? #7
think the 12 speed only availabe in 7060. that option get you 16gpm hydraulics and epto
   / It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K? #8
think the 12 speed only available in 7060. that option get you 16gpm hydraulics and epto
That is correct. I just went through this criteria when selecting my 7060 and I did buy the 12 spd.
   / It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K? #9
I did this wrong. 8-speed seemed like enough until I got it home. Now I have the rest of my life to regret my choice because, for my uses and cheap nature, I am not going to take a Mulligan on it.
   / It's time! M5660 or the M6060. Guys' Any sig. diffs to scoot us up the $2K? #10
and Weight: 5005 to 5358 pounds, 3pt Control: position control and top-link draft sensing and available Cab .
vs
Unless it has changed from the previous 40 series you have to step up to the M7060 for a factory cab
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
207282 (A52708)
207282 (A52708)
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
