It's PT 435 tire time.
   / It's PT 435 tire time. #1
Gravy
Platinum Member
SW Virginia
PT425
Long time no talk. My Subaru Robin EH90 (aka Generac GTH990-ish) engine swap in my 2006 PT425 is still going about 8 years later. But the Carlisle All Trail tires that I bought a number of years ago are coming apart. The tread knobs are barely worn down at all. But on two of the tires, cracks have developed at the base of the knobs, and air hisses out. I'm not unhappy with the tires. They've lasted longer than either the Carlisle Super Lug or Turf Trac tires that I tried before them. But I'm hoping to find something with better traction. My property has lots of steep spots, and the "soil" is generally crumbly decomposing rock of various types, and doesn't support deep root growth for any grass that may have the temerity to attempt to grow on it, so there is really no turf with a root network to hold it all together. It's all quite fragile.
So, I'm hoping to find some magical tires that will actually have better traction on these slopes than the ones I have mentioned, and will dig in and move the PT forward and upward rather than just spinning and ripping out any grass by the roots. Aside from the tires I've already mentioned, I've run across references to some ATV tires and new reproductions of Firestone ag tread/lug tires. Has anybody found something that has exceptional traction on loose, steep surfaces? Even running tire chains all year didn't work very well.
I'm hoping somebody will dope slap me and point me to something everybody else here knows about.
   / It's PT 435 tire time. #2
Sorry I can't help. I'm still on the original turfs (well, 3 of them. I destroyed 1 myself) that came with the machine in 2001. Got about 600 hours on them with very little wear.
   / It's PT 435 tire time. #3
I don't have a 4XX. So, I may be totally off base, but here goes.
FWIW: I have a 1445, with R4 tires, and during our wet season it has four wheel net chains. I'm often on 25-30 degree slopes, and I've noticed that the R4 tread slips on loose surface material (e.g. gravel, wet sap) on steep slopes. I've tried a variety of tire pressures that have no effect on those stiff tires. Chains help a lot, but at the cost of more ground tracks, and occasionally divots from spinning a wheel.
I think that the low ground pressure of the PTs that make them so good at floating over grass and soft soil also makes traction sensitive to the contact area. So, slick grass, wet sap, loose gravel causes reduced friction and reduced traction because the PTs "grip" just the top layer because they aren't sinking in, unlike typical tractors. I think regular lawn mowers are designed for pretty flat lawns, so I tend to ignore spin outs on slick areas, because not much happens.
I'm not sure that there is a magic tire tread, or we'd all be using it. I suspect that lawn tires (R3), which have the largest contact, area are probably the most sensitive, but I'm not sure that R1 or R4 would help that much. I'd try chains first. There are some Carlisle deep lug R4s ("Xtra Grip"), but I have not yet tried them. Like @MossRoad I am still running on my originals.
All the best,
Peter
   / It's PT 435 tire time. #4
You may want to try R14 tires, they are like a ag tread and turf tread combined in one.
Be careful when shopping ATV tires, they might not hold the weight.
Thanks, guys. I'm currently running Carlisle All Trail HDAP tires, which wear like iron. They are aging out with cracks in the rubber, slow leaks and other deterioration, but the knobs are still probably 75% of new height. I'd say they had significantly more traction than the Turf Savers, especially in snow (back when we got enough to plow), but the difference wasn't dramatic. Somewhere in there I went through a couple of sets of Carlisle Super Lugs. Other than deep mud, I can't really say they had great traction either. All three of those types of tires pretty much lost traction in the same places.
My "soil" is really fragile, being crumbly when dry from lots of decomposing stone in with the clay, and greasy when wet, except where I have added enough organic material over the years. The soil is also extremely rocky, and the big smooth ones that are more or less flush with the surface have terrible traction. At this point I'm considering Carlisle Tru Power and Firestone Flotation 23 lug tires or some hypothetical gnarly heavy duty ATV/UTV tire. The Firestones are apparently THE tire for stock class garden tractors in pulling competitions, which is a point in their favor, but I'm still going to investigate ATV/UTV tires since there are a lot of choices that are optimized for various conditions. Our old 2wd 4-wheeler can just calmly motor up slopes where the PT spins tires and struggles to make forward progress. I suspect the knobby tires have something to do with that.
   / It's PT 435 tire time. #6
I suggest you use the search tool to look for posts by KentT regarding his PT425 that he was using to mow in the East TN mountains. He upgraded his wheel motors to larger ones, and eventually went to using a 1430. But it sounds like you are going through similar issues, and perhaps some of his thoughts would be helpful to you.
That looks like it could work. Unfortunately, they don't appear to be available in a 23-10.50-12 size.
I ended up with Carlisle Tru-power lug tires. After lots of googling, I came to the conclusion that they should be the second most aggressive lug tire in my size. The reproduction Firestones are #1, but they would cost $1000 for a set with shipping from Miller Tire, where the Tru Powers were $480 from Amazon.
The TPs look a lot more aggressive than the Super Lugs that PT used to put on the PT425, with a very squared-off profile and heavier lugs, so I'm hoping they will work better than the rounded profile SL. Carlisle no longer sells the SL in this size, anyway.
   / It's PT 435 tire time. #9
Pictures when you get it done please
I found it interesting that the tires are also labeled with an automotive size. They ride noticeably stiffer than the All Trails, despite both being 4-ply.
Also, after doing the tire change, I have vowed that I will never again liquid fill tires. What a freakin' mess! I did it with a Harbor Freight changer for the experience, but I'd be a lot less sore if I'd had it done with a real tire machine.
Tire review after a few weeks: They do better out on the wooded hillsides than anything else I've tried. Think loose rocks on soft soil under a thick layer of dead leaves, going up slopes that challenge the wheel motors and sometimes win. They leave more visible tracks on the lawn than any other tires I've tried, likely because of the sharply squared-off shoulders, and they definitely tear up the ground in the woods.
They also ride like a freakin' buckboard. They are 4 ply, but they are stiffer than some 6 plies I've had, and the spacing of the lugs is wide enough that I sometimes feel each lug jolting me a little. I'm OK with the rough ride, because they have been getting me up to some really good dead firewood trees. When mowing season comes around again, I'll use another set of wheels with turf tires and a softer ride.
For those with larger budgets, I would bet that the Firestones would be even better at climbing my slopes, but for the money I like these. It will be interesting to see how they wear and how the traction changes as the corners and edges wear down.
   / It's PT 435 tire time. #13
I am running a 8 ply tire on my 2425 . I have set the tire pressure at 15 pounds and it works well. Havent had any flats with the 8 ply tires like i have had with the 4ply working in the woods all the time. The only problem i have is knocking the valve stems off on occasions. with the 8 ply on if i lose a valve stem, ( which i still do on occasion) the tire looks like it is just low on air and i can drive still drive out to get the tire swapped out untill iget the valve stem replaced.
I think a 2425 is quite different from my somewhat modified 435. But I have had tires stiff enough to drive on for a bit. These may be stiff enough for that.
Tire update: we had a couple inches of snow. Plowing snow straight ahead on the driveway, these tires did not slip on the asphalt when the pile of snow in front got pretty big. I'd say they did somewhat better than the All Trails, although it wasn't much of a test. They definitely have more traction in dirt, and they leave very visible tracks on soft or wet soil.
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
Mini John Deere Truck (A55853)
Mini John Deere...
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
Toyota SR1-BET35 3,500 LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
Great Dane Van Trailer 1989 (A61306)
Great Dane Van...
