It's just torture....
/ It's just torture.... #21
If you want to get rid of the leaves of the poison ivy plant, use a 1 part bleach - 2 part water mix and spray them. The bleach reacts with the oil and the leave is exposed. The vine lives on, only herbicide can get that. But most plants don't mind being sprayed so it's a good way to just get rid of the ivy. Be sure to clean the sprayer when you're done with it- that bleach will eat it up.
The oil in the ivy is a base (vs. an acid). So you get a base burn when your skin is exposed to the oil. That's why it takes a while for the effects to show up. So the bleach on the skin reacts with the oil and stops the burning process. The sooner you get the bleach on it, the less of a burn you will have. There is also an immune system response to the oil. Nasty stuff!
Congrats on the new tractor !
Pete
/ It's just torture.... #22
Gargle with Jack Daniels four times a day. No need to spit it out. The poison ivy won't hurt near as much. This also works for sprains, strains, mild annoyances with in-laws. Stuffs a bloody miracle drug.
/ It's just torture.... #23
Congratulations on the new tractor! Kubota is fantastic machine.
Go to your doctor and get a script for steroids. Over and done in a day or two. Just becareful while taking them. You will "need" to do way more than you normally do.
Thank you all for your replies, and especially for your congratulations on my new tractor. Got on the steroids yesterday, and have already noticed that I am leaking less. I might venture out today and start playing with the loader. I want to get smooth with curling/raising and dumping/lowering.
Speaking of which, I was hoping that our local Cooperative Extension might offer some tractor classes. Yes, I know that I can eventually figure out just about everything by my lonesome. But I have watched seasoned operators, and have been in awe. My thinking is if someone totally green like me could spend 8-10 hours watching, hearing explanations, playing under supervision, and getting feedback, the learning curve could be greatly improved. So far, I have found nothing.
On the poison ivy front, here is a story that I have heard from several different old timers: They said that when they were children, they had bad reactions to poison ivy. In response, their parents made them eat some of the leaves. They said it made them completely immune to the stuff. They said afterward, they could walk through it with no problems.
Now I'm not running out and making a salad for lunch, but it makes me wonder. Why didn't their throats swell shut? Why didn't they get severe stomach problems? And is there a chance it really works???
Take care all, and thanks again for your well wishes.
Nick
/ It's just torture.... #25
Nick
I know of no classes, but agree that they are needed much like the ATV safety courses. Ys, you can and will learn to operate your tractor safely and effectively, but some training sure would speed it along. I have been operating tractors for over fifty years and am still not to the point I would like and probably never will.
As to the Poison Ivy, I don't think there is any validity to the claims and would discuss any options with your doctor; don't think desensitization with this works like it would with snake venom and such.
/ It's just torture.... #26
Hi! I shurely would not eat it.... Maybe they had nothing because we have acid in the stomach??? but what about their lips ...If you burn poison ivy, the smoke will carry it , if smoke touches your skin, you will have it, if you breathe it it will harm your lungs badly and may cause your death.
I had it 3 times in 2 years ..had to have a cortisone treatment every time ..( pills and cream)...since then I fight it with herbicide ,the plants go brown but the next springs they come back.....but it is a fight to the finish. Good luck
/ It's just torture.... #27
I get poison ivy each summer now, have some as I type. The only relief I've found for the itchy is super hot water. Will make it itch like you've never felt anything itch before, crazy adrenalin rush. But once you do it you'll get relief for quite a long time.
The super hot water (as hot as I can stand) exhausts the histamines, which is what causes the itchy feeling. Takes a while for them to build back up.
The only way I can fall asleep some nights.
Joel
It's nice to see some good info, here. So many ivy threads turn into some serious acts of gore.
Since the skin is broken and an infection has set in, the OP certainly shouldn't be following any on-line remedies.:laughing: But... The histamine and adrenalin references are very important... More to the point, histamines and endorphins. The hot shower will release the histamines as well as produce endorphins, resulting in relief. It also opens the pours and releases the oil. After a hot shower, when there's still a bit of weeping from the ivy sores, I'll dab alcohol to dry it up and then cover up in baby/talcum powder. The powder at the end seems to help prevent the spread, as any weeping is immediately absorbed.
/ It's just torture.... #29
I can walk through poison Ivey or poison oak in flip flops and shorts and nothing..no reaction..I have always been immune but my wife, son, daughter in law are all suseptible to it..My daughter in law got deathly ill form just breathing the smoke one day when my son was burning it. Mosquitos never bother to bite me either...I don't know whether to be happy or wonder if I am toxic to the Ivey and the skeeters...LOL
/ It's just torture.... #30
Joel
+1 for hot water. I do it morning and evening and it really helps. Plus it is amazing sensation when the hot water hits the inflamed spot.
/ It's just torture.... #31
I have found four things that help with Poison Oak, in order.
1 - Stay far far away from it
2 - Technu to wash up, and for laundry
3 - Aloe. We have Aloe growing in a pot at home. Break a piece off, and rub it on the affected area
4 - Grandma's real lard/lye home made soap
I can not stay away from the stuff. It is on our property. Poison Oak, grows from sea level to about 3500' elevation.
Technu works really well; we have loads of it on th eire engine and at the station; nothing like wildland firefighting in the stuff!
We have Aloe growining on the back deck. It is easy to grow. It provides the best relief. Fresh from the plant is better than the cream and lotion from the store. I have done the hot water trick; it does help, but not as much as fresh Aloe.
My Grandmother used to make soap. It ws the best for poison Oak. But, she has been gone for 15 years, and Mom does not make it any more. I just have not gotten enthused to render lard to make it...
Another thing that has not been mentioned, is carefully undress, and do not touch your clothes; the oil will be on you clothes, boots ect. Straight in to the wash. Technu works good in the wash.
Also clean up good before you go to the bathroom. You do not want it "there"!
I have gotten it from the plant. Also from crashing dirtbikes in it. And, from the dirt bike or tractor, weeks after working/riding in it. I also get it from the dogs, who just ran thru it chasing squirrels ect.
Congrats on the tractor, BTW :D
/ It's just torture.... #32
Sorry to hear about your poison ivy episode. I've finally found something that works; it's called ZanFel and can be purchased at Walgreens. Only thing; it's expensive. about $35 for an ounce tube. Another less expensive option is to buy a large container of Mean Green hand cleaner. It is esentially the same thing as ZanFel. You can find the Mean Green at their web site and can order it on-line.
/ It's just torture.... #33
Just last weekend somebody told me to use Preparation H on poison ivy blisters. I tried it, seems to work.
I thought about using Preparation H, but it kind of made me feel like an...you know.:D
/ It's just torture.... #35
The best herbicide to kill poison Ivy or poison oak is 2-4D as roundup won't kill it . The best time to spray it is early in the season as the later in the season it is the leaves get a waxy film on them and won't absorb the 2-4D and so it won't kill it , it may take a couple of years to get rid of it but after that it won't be back .
/ It's just torture.... #36
I am very susceptible to poison oak and I carry disposable rubber gloves on my tractor for backwoods bathroom breaks. Much better than getting a rash on my hoo-hoo.
I have found that the pumice (gritty) GoJo hand cleaner is every bit as good as Technu, maybe even better, and is much less expensive. Do not use the slimy formula.
Roundup works on poison oak for me.
/ It's just torture.... #37
Joel
I've had both poison ivy and poison oak. For me the poison oak is far worse. But I also found that running the area under VERY hot water would lead to several hours of relief.
Thanks for the heads up on 2-4D working better than Roundup, Allan. I have never heard of 2-4D, but I will be acquiring some soon. And then, I am on a mission. I know it is late in the season, but I want to return the favor to these lovely plants, even if I don't kill them completely. Then I will be back at them next spring.
A poison ivy free property? Dare to dream...
Nick
/ It's just torture.... #39
Congrats on the new tractor, and sorry to hear about the poison ivy... hope it clears up soon! Since you are new to tractoring I will offer one of the single most important pieces of advice... when moving with a full loader bucket keep the bucket as low to the ground as possible, and always have your hand on the loader valve ready to drop it to the ground if you start to get "tippy".
Thanks WBL:
I read that in the manual, and now it has been underscored. I am working on making rear ballast. Forum members have had some great ideas and have generously posted them, along with pics. Ballast is my very next project.
Nick
2007 WESTERN STAR  4900 TRI AXLE (A67714)
2007 WESTERN STAR...
DYNAPAC CP142 ROLLER 9 WHEEL PNEUMATIC ROLLER (A67714)
DYNAPAC CP142...
18 FOOT WATER/FUEL TRAILER (A67714)
18 FOOT WATER/FUEL...
2013 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2013 FORD F150...
2013 CHEVROLET CRUZE CAR (A66091)
2013 CHEVROLET...
2018 JOHN DEERE 350G LC EXCAVATOR (A65056)
2018 JOHN DEERE...
