It's big, it's blue.. it's a 252!
/ It's big, it's blue.. it's a 252! #41
There's always metal-core to throw a loop in the system. ;) You want fast? Try some Innershield NS3M(E70-T4) I burned some 3/32" at about 400 amps and went through a 50 pound coil in less than than 2 1/2 hours. I could have turned it hotter too. You can get it in 1/8" as well. With the 3 /32" I could lay a bead about 1/2" wide moving my hand pretty quick. Slag comes off real easy and it is almost as smooth as sub-arc. If you get arc blow is another story.
The wire that was $55 was Uni-Braze. They sold lots of it. It's made in China but for $15 a roll cheaper, it works just as good.
Lifes full of choices. I choose to keep the guys up in Hawkesbury Ontario working making wire. Plus, buying AL wire keeps a good relationship with my LWS, who gave me a heck of a deal on the new machine.
For $15 savings, and the above reasons, chicom wire won't be on my machine. If AL closes the Hawkesbury plant and begins offshoring, then I will consider other options.
/ It's big, it's blue.. it's a 252! #43
Apparently they have closed the Hawkesbury warehouse. Don't know about the wire plant.
Jack Daniels Metal Decorative Sign (A66738)
Jack Daniels Metal...
Unused Hustler DG LM200 SS 79in Hydraulic Dual Cylinder Grapple Loader Tractor Attachment (A66734)
Unused Hustler DG...
2016 Dodge Grand Caravan Van (A66738)
2016 Dodge Grand...
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
20 Ton Air/Manual Hydraulic Bottle Jack (A64557)
20 Ton Air/Manual...
2011 John Deere CX15 (A64911)
2011 John Deere...
