It's About Time Deere
/ It's About Time Deere #1
Paystar
Elite Member
Ontario, Canada
Kubota B2620
You would have thought this would be a no-brainer for a company that makes farm equipment to support the corn growers that buy their equipment.
/ It's About Time Deere #5
Alcohol from corn will always be energy negative as a fuel and no amount of technology will ever make up for thermodynamic inefficiency. It's not energy dense and IMO there could only be a emissions angle to make it sound worth Deere exploring.
So hopefully they can save $$ on DPFs & DEF tanks and I wouldn't expect a lower price on farm tractors, but the system may be polished up in time to meet Tier VIII. I expect common rail injectors will be the easy part, typically not leak/drip, or require close tolerances. :rolleyes: Minimal visible flames if a high pressure line breaks? Check. Keeping water out of fuel, easy enough. Economical Sched 200 SS lines might get pricey to replace but nothin' Deere can't work with.
btw, who needs CRP lands when corn subidies pay better anyway? Will we make good use of our territory or just let the animals take it back from us? o_O
/ It's About Time Deere #6
/ It's About Time Deere #7
Other than energy concerns the main drawback to introducing ethanol in fuels was it's effect on metals. Adequate research and modifications were not done prior to it's introduction. Add to that the small engine industry was slow to get on board and a large segment still has not.
Protective coatings, resistant fuel components, and fuel injection is required.
As far as getting it to burn in a compression ignition engine it probably just needs lower compression, a lubricant added, along with a change in injection timing.
Using materials that resist the corrosive effect will be the challenge.
/ It's About Time Deere #8
/ It's About Time Deere #9
Don't know if anyone has seen this but if
anyone has this type of John Deere unit
and you have to remove this screw be very
careful this guy says its very expensive!
willy
/ It's About Time Deere #11
rScotty was looking at youtube you can find all
kinds of stuff on there
So if anyone has that type of machine they
have a heads up
willy
/ It's About Time Deere #12
willy
He doesn't seem real bright.🤪
/ It's About Time Deere #13
Well he seems to have front teeth. That's something, isn't it?
We've been informed. 🔧 (Everyone clapped)
2022 EZ-GO ELITE...
Woods BW180HD Batwing Mower (A66285)
Woods BW180HD...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
150 GALLON FUEL TANKS (A65643)
150 GALLON FUEL...
case 370 glass door never installed (A61307)
case 370 glass...
GYRO-TRAC (A65053)
GYRO-TRAC (A65053)
