It's 5am and the brisket is in the smoker
   / It's 5am and the brisket is in the smoker #11
I built my smoker out of a 55 gal. Drum.
   / It's 5am and the brisket is in the smoker #12
Happy memorial day! Brisket and a small rack of lamb should be ready in about 12 hours. Smoker is at about 250 degrees and the meat is in.
I do long smokes, things like butts and briskets, overnight. I have an alarm light rigged up on it that wakes me up when I need to add fuel, lump and chunk in my case. Stuff like ribs cook a lot quicker so those I usually start sometime around noon. I do most everything at 225 F and cook to internal temp in most cases. Ribs, chicken and fish are mostly by time though and cook quick.
   / It's 5am and the brisket is in the smoker #13
The smoker is called a pit barrel cooker and it's basically a 30 gallon drum with a couple holes drilled in it for some rebar to hold the hooks to hang your meat from. It's a no frills setup despite the $300 price point (which in retrospect seems high as I could have just bought a drum and made this myself. But the kit is put together nicely and set up perfectly from the factory. At the bottom is a basket for charcoal. Temperature holds tight at 270 when the charcoal is hot. After about 5 hours temp was down to 200, added more unlit kingsford and temp came back up. After 6 hours the brisket is up to about 185 internal temperature and starting to soften up. View attachment 511030View attachment 511031View attachment 511032
Love my Pit Barrel Cooker - the owner was in Armed Forces... Each PBC purchased a donation is given back to Men & Women in uniform. Muhammad your Lamb looks awesome, you're knocking it out!
Brisket is done! After a few slices I remembered to rotate the brisket and cut against the pointe grain. Quite tasty.
   / It's 5am and the brisket is in the smoker #15
Looks good. Did some tri tip on the grill
And smoked 2 racks of spareribs and one of baby backs
   / It's 5am and the brisket is in the smoker #16
Wow. You guys are some serious overachievers. We just threw a dozen brats on the grill at lunch, and warmed the leftovers for dinner.
Everything looks delicious, though.
2006 KENWORTH (INOPERABLE)T800 (A55745)
2006 KENWORTH...
2020 ASV VT70HO Skidloader (RIDE AND DRIVE) (A50775)
2020 ASV VT70HO...
2015 Ford F450 Stake Body Dump (A47477)
2015 Ford F450...
2011 New Holland Boomer 90 MFWD Utility Tractor (A55302)
2011 New Holland...
John Deere skidsteer (A55788)
John Deere...
