Iseki TX1410F Hydraulic Issues
/ Iseki TX1410F Hydraulic Issues #1
Goodtimes
Saskatoon Sask
Iseki TX1410F
I need help trying to get my hydraulics to lift on my Iseki TX1410F, it does not have a loader just a roto-tiller, if I manually lift the tiller it will stay up but it will not lift on its own. I replaced the O-rings on the piston, the screen is clean and has new oil. How do I make sure the valve is set correct? Also is it time to bite the bullet and replace the pump or can it be rebuilt? Or where can I get a used one without getting gouged to bad? I know this is a lot of questions but I really like this little tractor and it has been so handy on our acreage I miss using it!!!
/ Iseki TX1410F Hydraulic Issues #2
You really need a flow and pressure test to see if the pump is performing like it should.
You can do a relief valve test if the pump is pumping like it should, by installing a 3000 psi gage before the 3pt.
Pressure is developed by the load, so a light load may only show 1000 psi, whereas to lift a heavy load, the pressure developed might be in the 2500 psi range.
You pump probably can be rebuilt if needed.
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F-250...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
Club Car Emergency Cart (A64557)
Club Car Emergency...
Gehl Mix-All 95 Grinder-Mixer (A66408)
Gehl Mix-All 95...
New/Unused Wolverine 43in Mini Rock Bucket (A65583)
New/Unused...
2019 Dodge Charger Sedan (A64557)
2019 Dodge Charger...
