Iseki TS1910 Dash Lights
/ Iseki TS1910 Dash Lights #1
Kiona Farm
NW North Carolina
Iseki TS1910
What do the three lights on the right side of the dash represent? I have one coming on and want to make sure that my machine is tip top.:)
/ Iseki TS1910 Dash Lights #2
From left to right they should be oil light, charge light, and water temp light.
Thanks for the info. Would you have any idea what would make the water temp light come on and stay on at cold start up? It just started doing this the last two times that I used it.
/ Iseki TS1910 Dash Lights #4
Could be the ignition switch (key switch) not returning properly or the temperature sending unit (thermocoupling). The wire may be broken or pinched to ground (shorted).
Thanks Robert. I have lost my key some time back and found that one of the accessories on my swiss army knife works very well...:eek:. I just keep it in my pocket when using the tractor. I did notice that the light would go out for a fleeting moment with the engine running if I turned the switch off and on back and forth. Where is the temp sensor located so that I might do a ground check and hopefully omit one of the two options?:)
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
TAKEUCHI TL8 SKID STEER (A60429)
TAKEUCHI TL8 SKID...
207283 (A52708)
207283 (A52708)
UNUSED FUTURE FT13 EXCAVATOR (A60430)
UNUSED FUTURE FT13...
UNUSED KJ K1912 - 20' X 12' LIVESTOCK METAL SHED (A60432)
UNUSED KJ K1912 -...
