Iseki TS1910 Dash Lights
   / Iseki TS1910 Dash Lights #1
Kiona Farm
NW North Carolina
Iseki TS1910
What do the three lights on the right side of the dash represent? I have one coming on and want to make sure that my machine is tip top.:)
   / Iseki TS1910 Dash Lights #2
From left to right they should be oil light, charge light, and water temp light.
Thanks for the info. Would you have any idea what would make the water temp light come on and stay on at cold start up? It just started doing this the last two times that I used it.
   / Iseki TS1910 Dash Lights #4
Could be the ignition switch (key switch) not returning properly or the temperature sending unit (thermocoupling). The wire may be broken or pinched to ground (shorted).
Thanks Robert. I have lost my key some time back and found that one of the accessories on my swiss army knife works very well...:eek:. I just keep it in my pocket when using the tractor. I did notice that the light would go out for a fleeting moment with the engine running if I turned the switch off and on back and forth. Where is the temp sensor located so that I might do a ground check and hopefully omit one of the two options?:)
2017 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2017 Ford F-450...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2019 FORD F-350 SERVICE TRUCK(INOPERABLE) (A50854)
2019 FORD F-350...
2012 KENWORTH T800(INOPERABLE) (A50854)
2012 KENWORTH...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
