Iseki TS 2205
/ Iseki TS 2205 #1
ffackler
I am looking for service information on this tractor such as types of engine oil, gear oil hyd oil and capacities.
/ Iseki TS 2205 #2
Good luck unless you can read Japanese. A TS2205 was only built in Japan. If you contact Len Schaffer here on these boards he can help you some but all I ever found was written in Japanese.
If you need a TS2205 for parts I have one for sale.
Don
/ Iseki TS 2205 #3
I have a TS1610F that's got a 975cc displacement Isuzu engine. My service manual also lists a TS2220 w/ 1184cc engine, so maybe that's about the same as yours. It lists capacities for the TS2220 as follows:
Engine: 3.59 qt. (3.4L) SAE 30W @ 70 deg.F and up, SAE 20 or 10W/30 @ 32 deg.F. to 70 deg.F., and SAE 10W below 32deg.F. (all of these should be Heavy Duty diesel service type);
Injection Pump: 0.12qt. (0.11L), use the same as engine oil;
Steering Box: SAE 90W Gear Oil (replenish as needed)
Transmission Case: 11.1qt. (10.5L) Gear Oil SAE 90W
Hydraulic Cylinder Case: 5.81 qt. (5.5L) Hydraulic Fluid (I use Wal-Mart's Super Tech Heavy Duty Tractor Hydraulic & Transmission Oil, meets John Deere J20C, D/JDT 303, Quatrol specification as indicated on the back panel);
Radiator: 6.45 qt. (6.1L); I use 40% antifreeze/60% water
Fuel Tank: 4.23 Gal. (16L) Diesel of course
4x4 front axle: 4.76 qt. (4.5L) SAE 90W Gear Oil
....and lots of grease zerks to hit!
Bill in CO
/ Iseki TS 2205 #4
The Bolens G244 is very close. I can supply operator, ,service & parts books. Usually I have them in stock.
2011 Komatsu D61PX (A64126)
2011 Komatsu D61PX...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
Kobelco SK135SRLC-1E, Cab, Heat/Air, Manual Thumb8 (A62679)
Kobelco...
John Deere 4020 Loader Tractor (A66285)
John Deere 4020...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
2021 John Deere 5100E (A64126)
2021 John Deere...
