Iseki TS 2205
/ Iseki TS 2205 #1
ffackler
I am looking for service information on this tractor such as types of engine oil, gear oil hyd oil and capacities.
/ Iseki TS 2205 #2
Good luck unless you can read Japanese. A TS2205 was only built in Japan. If you contact Len Schaffer here on these boards he can help you some but all I ever found was written in Japanese.
If you need a TS2205 for parts I have one for sale.
Don
/ Iseki TS 2205 #3
I have a TS1610F that's got a 975cc displacement Isuzu engine. My service manual also lists a TS2220 w/ 1184cc engine, so maybe that's about the same as yours. It lists capacities for the TS2220 as follows:
Engine: 3.59 qt. (3.4L) SAE 30W @ 70 deg.F and up, SAE 20 or 10W/30 @ 32 deg.F. to 70 deg.F., and SAE 10W below 32deg.F. (all of these should be Heavy Duty diesel service type);
Injection Pump: 0.12qt. (0.11L), use the same as engine oil;
Steering Box: SAE 90W Gear Oil (replenish as needed)
Transmission Case: 11.1qt. (10.5L) Gear Oil SAE 90W
Hydraulic Cylinder Case: 5.81 qt. (5.5L) Hydraulic Fluid (I use Wal-Mart's Super Tech Heavy Duty Tractor Hydraulic & Transmission Oil, meets John Deere J20C, D/JDT 303, Quatrol specification as indicated on the back panel);
Radiator: 6.45 qt. (6.1L); I use 40% antifreeze/60% water
Fuel Tank: 4.23 Gal. (16L) Diesel of course
4x4 front axle: 4.76 qt. (4.5L) SAE 90W Gear Oil
....and lots of grease zerks to hit!
Bill in CO
/ Iseki TS 2205 #4
The Bolens G244 is very close. I can supply operator, ,service & parts books. Usually I have them in stock.
100 Gal Oil Container (A64127)
100 Gal Oil...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
2021 New Holland 1428 Rake (A63688)
2021 New Holland...
Pemberton Inc Komatsu Grapple Bucket (A64194)
Pemberton Inc...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63689)
2019 Takeuchi TL8...
2021 Case TV450B (A64126)
2021 Case TV450B...
