Iseki Over Heating
/ Iseki Over Heating #1
trott
I have a 2 cylinder diesal and it is getting hot. I flushed the radiator recenlty and since then it has over heated. The thermostat is out and the radiator is clean on the front. No leaking from the water pump and no signs of a head gasket problem. Any suggestions would be great. I may pull the raidator and have it re-done. Thanks in advance for any help. Trott.
/ Iseki Over Heating #2
First thing I'd do is replace that thermostat. The coolant may be flowing though too fast (not allowing enough time in the radiator to dissipate heat).
If that doesn't work, then pull the radiator.
Another thing to try is back flushing the radiator.
/ Iseki Over Heating #3
Is it possible that when you flushed the radiator it plugger off 1 or more of the u tubes? another question is why did you feel the need to flush it ? was it giving you a problem?
/ Iseki Over Heating #4
Do a flow test with a garden hose.. a good radiator should be able to keep up with a half inch garden hose..
Soundguy
/ Iseki Over Heating #5
How much antifreeze did you put back in? Antifreeze does not dissipate heat nearly as well as water and with too heavy of a mixture you can cause overheating problems.
Engines should be ran at certain temperatures to maximize power and fuel economy. Without a thermostat you will almost always be running the engine at a lower temp than it was designed to. I would recommend putting a thermostat back in along with addressing any other cooling problems you might have.
2020 INTERNATIONAL RH613 6X4 T/A DAY CAB TRACTOR (A59909)
2020 INTERNATIONAL...
2019 Autocar ACX Xpeditor T/A Heil 31Yd Side Loader Garbage Truck (A61568)
2019 Autocar ACX...
2017 Dodge Journey SUV (A61569)
2017 Dodge Journey...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2006 Ford F-650 S/A Dump Truck (A61568)
2006 Ford F-650...
