Iseki dash lights
/ Iseki dash lights #1
DodCX
Iseki TX100f
Anyone got a solution for missing charging lamps and water temperature lamps on the dash? This is for a tx1500f. I imagine nobody makes them anymore but perhaps someone has found a good match? Thanks. I'm missing some indicators too and again I wonder if anyone has fitted any aftermarket ones. Thanks.
DodCX
/ Iseki dash lights #2
If you just need the bulb, they are BA9s base, 12V, 3watt. Should be able to get them off eBay. If you need the holder or lens, check shaeffer tractor or southern global tractor, both have parts tractors and new stuff.
As far as I can tell, the sending units are just a simple switch, they won't support a gauge. That said, you could probably find a sender that does.
/ Iseki dash lights #3
The lamps are likely standard lamps available on eBay or a NAPA dealer. I got tired of the too frequent over temperature light on my Mitsubishi and put a gauge on the dash in place of the factory light. Later I fixed the cause of over temperature.
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2009 International 4300 Box Truck 24' (A62613)
2009 International...
2012 FOR F150 REGULAR CAB PICKUP TRUCK (A66091)
2012 FOR F150...
213063 (A64276)
213063 (A64276)
CAT 980C GP Bucket (A68134)
CAT 980C GP Bucket...
