Iseki dash lights
/ Iseki dash lights #1
DodCX
Iseki TX100f
Anyone got a solution for missing charging lamps and water temperature lamps on the dash? This is for a tx1500f. I imagine nobody makes them anymore but perhaps someone has found a good match? Thanks. I'm missing some indicators too and again I wonder if anyone has fitted any aftermarket ones. Thanks.
DodCX
/ Iseki dash lights #2
If you just need the bulb, they are BA9s base, 12V, 3watt. Should be able to get them off eBay. If you need the holder or lens, check shaeffer tractor or southern global tractor, both have parts tractors and new stuff.
As far as I can tell, the sending units are just a simple switch, they won't support a gauge. That said, you could probably find a sender that does.
/ Iseki dash lights #3
The lamps are likely standard lamps available on eBay or a NAPA dealer. I got tired of the too frequent over temperature light on my Mitsubishi and put a gauge on the dash in place of the factory light. Later I fixed the cause of over temperature.
2022 TYM T474 TRACTOR (A65057)
2022 TYM T474...
CAT 963 4-in-1 Bucket (A68134)
CAT 963 4-in-1...
2023 CATERPILLAR 239D3 SKID STEER (A65056)
2023 CATERPILLAR...
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A66734)
2025 GIYI GY-P45...
2007 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2007 INTERNATIONAL...
2011 STEPHENS 200BBL CRUDE TANKER (A67714)
2011 STEPHENS...
