Is this possible?
/ Is this possible? #1
Jordan9682
Southwest sk
New holland 9682
I have a hand sprayer and I want to know if I would be able to take the hand wand off and make a small boom for it (only about 4' wide) and use it behind a quad? (Mount it up on the back of the quad, or on a small trailer. If on a trailer i would put a long handle on it so i could still pump it easily) I know the arm would get tired, but I'm cheap and just want to know if this is possible?
/ Is this possible?
Somethin' like this
/ Is this possible? #4
I'm sure that this is possible. I would think that you would be doing a good deal of hand pumping. Using one hand for the throttle and brake and pumping with the other hand would make steering the ATV interesting.
/ Is this possible? #6
I have a 15 gallon 12 volt sprayer on my ATV that I use to spray my fence lines. On my Polaris the throttle is on the right hand grip and the brake is on the left hand grip. And I gotta steer with something. Factor in another hand to operate the sprayer lever on my spray wand. Doing all of this and trying to pump a hand sprayer would probably turn me into warm jello. I can do some multi-tasking. But not that much.
/ Is this possible?
I probably won't spray a large area, so I could foot it i suppose
/ Is this possible? #8
The small 12 volt sprayers aren't all that expensive. You can cover a very large area with a hand wand. I have used mine for food plots. I don't have a boom. Mine is over twelve years old and except for replacing an occasional sprayer handle it has been trouble free. It was money well spent for me.
/ Is this possible? #10
Another consideration is adding nozzles will drastically effect how much pumping action is needed to give a consistent flow. Add a second nozzle it will take 2 times the amount of pumping.
/ Is this possible? #11
At $569, I would hope that it did an excellent job.:)
The ad claims 100% no drift and 5-acre coverage with one fill. These claims and the photo make me think that this is a variant of a rope wick applicator. If so, you could buy a rope wick applicator or build you own for a lot less.
As another poster mentioned, adding nozzles is going to increase the amount of pumping required.
You should be able to find a 12-volt ATV-mount boom sprayer for a lot less than $569. TSC in the States has one for $230 (Fimco 15 Gallon ATV Mounted Sprayer - Tractor Supply Online Store).
Steve
/ Is this possible? #12
Solo may still make the 4 ft. boom sprayer for there backpack sprayers. It replaced the nozzle, and mounted on the metal frame, that allowed you to walk and spray. Sold one to a customer a few years back that he mounted on his quad, and used his 12v sprayer to power it.
/ Is this possible? #13
northern tool has a boom kit that you can add to a sprayer. I think its $79. It claims you can use the lower powered pumps with it as well. Of course it would be just as cheap almost to buy a 25 gallon sprayer with a boom already but if your like me and have a 15gal sprayer already it may be the ticket.
2021 Kubota RTVX1120 (A64127)
2021 Kubota...
Vermeer S450TX (A64126)
Vermeer S450TX...
Luck Now XLR 4750ST (A64126)
Luck Now XLR...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
