Is this normal? (coupler pix)
/ Is this normal? (coupler pix) #2
I have the same coupler on my 14K 25' trailer, I will look this weekend and get back with you. Can you still operate it the way it's supposed to be or is it bent over?
here is pictures of mine
/ Is this normal? (coupler pix) #3
If your talking about the latch twisted off to the side, it's nothing to worry about. Just twist it back forward.
/ Is this normal? (coupler pix) #4
Did it get like that from the properly latched position? If so I'd be very concerned.
If it was simply latched down like that from the unlatched position, I'd just be sure to do it right and not twist it when latching.
Whether it was done when latching or from an already latched position- will it do that with a ball in it? The pic shows it with no ball in it.
I have the same/similar coupler on my dump trailer and haven't had it do that.
/ Is this normal? (coupler pix) #5
The shaft is probably threaded into the dog that locks under the ball when the lever is down. By turning the lever (and shaft) you can tighten or loosen the fit around the ball. Too tight and it may twist the ball when you turn; too loose and the coupler may come off.
/ Is this normal? (coupler pix) #7
There is a nut on the bottomof the coupler you need to just tighten it enough that the spring keeps the hook engaged. Can be trickey to get so it istill goes on and off easy and the spring stays in place.
Thanks Jimi,I appreciate it.It is only pushed over for the purpose of taking the picture.It still seems to work.
Jim the problem isn't that it wont stay engaged,it does.I just want to make sure it isnt defective because I've never seen one do that.
Thanks for the post FF,I learned something today,I didn't know they were adjustable.
I think it will do it with the ball in too.And it does latch and stay in place.
weldingisfun said:
How large a trailer do you have? If it is 12' or +, I would be looking at replacing the hitch with a Bulldog Bulldog Hammerblow trailer hitch ball couplers.
I'm going to have to put my faith in the trailer manufacturer on this one.I'm not likely to buy a new hitch setup on a brand new trailer :)
It is on a 18' 12k # tilt bed
/ Is this normal? (coupler pix) #14
I have the bulldog coupler on my trailer,the lever swings instead of lifting. I have to be carefull not to pinch my fingers when locking,unlocking it. plowking
Willl said:
I must be on his 'Ignore list'.
No your not on my ignore list?Perhaps I'll put you on my "overly sensitive list"?
1999 38ft Beverage Trailer (A65563)
1999 38ft Beverage...
2009 389 Peterbilt Winch Truck (A62679)
2009 389 Peterbilt...
2004 Club Car Carryall 6 Medical Utility Cart (A64553)
2004 Club Car...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
1000 GALLON POLY NURSE TANK (A64277)
1000 GALLON POLY...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
