Is this a Ford 4000 TLB?
/ Is this a Ford 4000 TLB? #1
DavesTractor
Elite Member
Red Bluff, CA
Changes often!
I just took in trade a nice older TLB. I don't know much about these older Fords, so I could use some help. I looked at "The Vintage Ford Tractor Resource" on the web to try to decipher the model/VIN number, but I still wasn't able to figure it out. The numbers stamped on the pad behind and above the starter are 41301 and then 28569. The later number has a diamond before and after it which I think means it has cast iron cylinder sleeves. The loader is a 720 and the hoe is a 723. It has power steering and is gas. It has a PTO but no three-point. The hoe/loader is sub frame. It was blue early in it's life.
Any help would be appreciated.
Another picture
And another
different angle this time....
dash area....
/ Is this a Ford 4000 TLB? #6
Dave
I'm not sure what your's is , but I've attached a few pictures of Ford 4000's that I found on the web. Picture is of 63 Ford 4000
Andy
/ Is this a Ford 4000 TLB? #7
64 this time
/ Is this a Ford 4000 TLB? #8
Diesel version
/ Is this a Ford 4000 TLB? #9
is it posible that it might be a case?
just a quess /forums/images/graemlins/cool.gif
/ Is this a Ford 4000 TLB? #10
Might be a conversion. Hoe looks like a Wain Roy. Probably has a hydraulic pump on the crank snout...
bky,
I'm sure it's a Ford, just not sure of the model.
Scott,
Both the loader and hoe have Ford ID tags and numbers on them, so I think they are Ford. It does have a crank mounted pump.
/ Is this a Ford 4000 TLB? #13
I had an industrial model Ford 4000, but it had a huge cast iron nose and grill. The tractor you are showing is not the industrial model, but it might be a regular 4000. Sorry I can't help much because I gave away all my reference manuals when I sold the tractor. Mine was blue and yellow.
Also, the hydraulic reservoir was up under the cast iron nose, and the pump was on the front of the crank as you describe. The nose ended just before the hood lift-up hatch. Somewhere I have a picture of the "beast" I'll try to find this weekend and send you a scan.
/ Is this a Ford 4000 TLB? #14
Could be an 800 series,hard to tell by the pic,they were very popular and look like the one in the photo you have. Nice piece
/ Is this a Ford 4000 TLB? #15
My photos are so far away that there is no detail. This is a toy model I found and I think it's funny because it is the same color as your tractor.
So it looks like I might have a 4000, but it is not the Industrial model. Thanks for the help and if anyone else can positively ID this tractor it would be appreciated.
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2015 Kubota...
2011 SHOP MANIFOLD TRAILER (A58214)
2011 SHOP MANIFOLD...
2016 Chevrolet Tahoe SUV (A59231)
2016 Chevrolet...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
