Any tractor with rear tires larger than 26 X 12 - 12 is not a SCUT. Any SCUT without position control on the three point hitch is not a tractor.
There was a lot of food put on the table by JDs, FARMALLs, OLIVERs, and ALISS CHALMERSs tractors 60-70 years ago. If I understand this SCUT topic correctly, that is of little consequence.
A tractor with 26 X 12 - 12 rear tires (SCUT), and no position control on the three point hitch, would fall into a lesser category, like garden tractor or something like that. If the tractor has 27" or larger tires on the rear and still has no position control on the three point hitch, well then it just kind of falls in to the "not very easy to work with category".
The 3 pt hitch was designed and patented with DRAFT control only. Ferguson designed it and had it on his black demonstration tractor, and then used on the 9N. The 8N came out with a lever that when activated, gave it
position control.. The Nebraska Tractor Tests said it was a tractor. There are other tractors with 3 pt. with smaller
wheels with draft control only. I would not call them a garden tractor...
Tom
While some may argue the point about size classification I think it is good to have this in between size available. I personally don't need it but others might and at least it is an available alternative. If if fits your needs I wouldn't worry about which size it is.
Actually, Mahindra is starting to use the term "Mid-CUT". Their Max line is closer in size and performance to the smaller Kubota B models than the BX's (and the same thing with several other brands). Maybe they figure some buyers won't notice that other brands offer comparable size models.
