Is the 3203 a step down from the 790
/ Is the 3203 a step down from the 790 #1
offroadr
Bronze Member
Central IL
JD 3320
I tell ya I have a hard time figuring out JD's CUT lineup!
My dealer says that the 790 is getting hard to get due to its replacement by the 3203. But the lack of mid hyd makes the 3203 not desireable for me. So then you step up in the 3000 series and spend more $$
Any of you experts figured this out yet?
/ Is the 3203 a step down from the 790 #2
It was my impression that the 3203 was an addition to John Deere's line up and not intended to replace the 790. If you really want a 790, I would check with another dealer to confirm that story. Except for similar engine power, there are quite a few differences between the 3203 and 790 to suggest that the 3203 isn't a replacement. The most significant being that the 790 is a gear tractor vs. the hydrostatic drive of the 3203.
Your post mentioned that the 3203 doesn't have "mid hyd" which I assume you mean the hydraulic outlets on the right side just ahead of the platform. This information is not true. The 3203 does have a standard duel hydraulic valve with the couplers in the same location as the other 3000 series. You cannot however get a 3rd rear outlet, which is available on the 3000 series.
You also cannot get a mid-PTO, so no belly mower or front snowblower for this tractor.
From a size and weight standpoint, I think the 3203 is actually a heavier duty tractor than the 790. It appears to me that a 3000 series drivetrain (which goes up to 40 HP or more in a 3720) was defeatured to provide a lower cost hydro option.
From my casual observation here are the difference between the two:
Transmission: 3203 HST, 790 Gear
PTO: 3203 electrohydraulic, 790 mechanical with two stage foot clutch.
Mid PTO: Available for 790, not for 3203.
Seat: 790 has a better seat
Platform: 3203 much nicer (similar to other 3000 Series)
Noise: It seemed to me that the 3203 was louder. Probably because of the higher speed engine and less engine coverage.
3 pt lift capacity: Check the specs, but I am sure the 3203 can lift substantially more weight.
Weight: 3203 is a bigger/heavier tractor.
Roger, sorry I had a brain fade! I meant mid-PTO not mid hyd.
Thanks for the thoughts. Yea I don't know if the dealer was wrong about the 790 replacement but the lack of mid-pto takes it off the list for me /forums/images/graemlins/smile.gif
/ Is the 3203 a step down from the 790 #4
The 790 and the 3203 are both current models....
The 790 is a step down in horsepower and transmission option is also a downgrade from the 3203.
As far as I know the 790 is not scheduled to be out of production for a while.
JD DLR
Rogator RG1300C (A63118)
Rogator RG1300C...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
(2) 9.5-24 TIRES W/8 LUG RIMS (A62130)
(2) 9.5-24 TIRES...
UNUSED JCT 84" HYD DOZER BLADE (A62131)
UNUSED JCT 84" HYD...
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
