Hyd Pump brand
/ Hyd Pump brand #21
I checked the numbers on Mobilfluid 424, which is a high quality equivalent of most common tractor hydraulic oils. Viscosity is 55 CSt at 40C and 9.3 at 100C. Since you can measure temperature, find out what the temperature is when you have the problem. It could be the implement section of your pump is worn to the point it will not build pressure. Finding a replacement pump outside of the OEM is difficult when you get into multiple section pumps. Your tractor has a 14.53 cc implement section and 6.61 cc steering section. Fortunately the reliefs are external so that doesn't complicate the selection.
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2012 PETERBILT 388 FLATTOP SLEEPER (A67714)
2012 PETERBILT 388...
More info coming soon. (A64557)
More info coming...
2018 CATERPILLAR 573D FELLER BUNCHER (A65053)
2018 CATERPILLAR...
