is my starter bad??????
/ is my starter bad?????? #1
bassfishrman
Alabama
YM 240
My tractor will not turn over unless jumped off. The battery is good and reads 12.6 volts. The dash lights and headlights are very bright so I know the battery is "hot".
If it is the starter...will a 72 datsun starter fit it?
My tractor is a YM240.
Thanks.
/ is my starter bad?????? #2
If it will jump start from another battery, the starter is probably good. What are the CCA's, (cold cranking amps), of the tractor battery and the jumper battery? Possibly you need a larger battery.
/ is my starter bad?????? #3
From what I understand, A 1972 Datsun 510 voltage reg. and alt. will work. Think the alt. is Hitachi. That starter is not the same as a Datsun 510. I know the volt. reg. will work cause I change the old mech. reg. with a 72 Datsun 510. Works great.
/ is my starter bad?????? #4
I think you might have a bad ground, check where the neg. battery cable is bolted to the frame, clean the rust and try it again?
/ is my starter bad?????? #5
These starters can be rebuilt. You should have a rebuilder in your area. If you do it it will last for years. Hoye and others have have starters. 72 datsun will not fit.....
i cleaned the ground...still not cranking without jump start and is even sluggish with jump start
/ is my starter bad?????? #7
I think I'd pull that starter and take it to a good rebuilder, Could be as simple as new brushes, commutator cleanup and some new bushings to fix her right up.........
Finally solved my cranking issues!
Guess what...bad battery....uurrgg! Funny thing is I just took the battery to autozone a few weeks ago and they said it was good. It has been reading 12.60 volts so I assumed they were right. Wrong. Apparently, the volts my meter was showing was surface volts.
Put new battery and cranked fine. I checked to make sure the battery was being charged under load and found that it was not. I replaced the alternator and voltage regulator since mine were the original ones. Still no charging under load.
Finally got a local mechanic friend to help me. He traced wires for about 30 minutes and found the fuse blown. As a matter of fact 3 of the 4 fuses were blown. He is installing a more modern fuse box with new fuses.
So my problem in the beginning was a blown fuse that was not allowing my alternator to charge the battery which ultimately killed my battery.
My next project will be to rewire the tractor.
Thanks for everyone's help. Hope my findings will help someone in the future.
/ is my starter bad?????? #9
You should change the batt. cables too. After I replaced my battery, volt. reg, and batt. cables, I haven't had any problems.
/ is my starter bad?????? #10
"So my problem in the beginning was a blown fuse that was not allowing my alternator to charge the battery which ultimately killed my battery."
Your old battery was more than likely still good, just needed charging. 12.75 volts is a full charge for a 12.6 volt battery, (they are not 12v batteries). I don't believe anyone can sucessfully own/operate/maintain a used tractor without owning/using a volt/ohm meter.
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
2012 WESTERNSTAR 4900FA (INOPERABLE) (A63569)
2012 WESTERNSTAR...
DEUTZ FAHR 4080E TRACTOR (A65057)
DEUTZ FAHR 4080E...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
CATERPILLAR H95-S HYD HAMMER (A65056)
CATERPILLAR H95-S...
HOSE REELS (A68842)
HOSE REELS (A68842)
