Rotary Cutter Is my bushhog too heavy
   / Is my bushhog too heavy #21
If your tractor has the ability to set the restriction on the 3ph (usually a knob under the seat) you may have luck by twisting it wide open and then all the way shut a couple times , then try to adjust it for the weight. Sometimes a little piece of gunk can prevent the valve from operating like it should and opening it up can flush it out.
   / Is my bushhog too heavy #22
sorry dirt ditch i wasn't trying to steal your thunder i looked up and saw you post just after i posted mine...like minds.lol
Everything you said except it stays without the bushhog
Thanks dirt ditch , will try today , deere service guy never mentioned this
   / Is my bushhog too heavy #25
Everything who said? Use "reply with quote" or identify in some other way.
Many of the things said here have no bearing on whether the lever itself will stay in the position you set it. It sounds like the lever moves too easily and wont stay at the correct setting while being jiggled by tractor and implement motion - unless you tie it. If this is correct just fix it by working on its pivot point to increase friction.
larry
That is correct , Thanks Larry !
   / Is my bushhog too heavy #27
well that was like pulling teeth..
   / Is my bushhog too heavy #29
could have been arrived at dfaster if that lil tidbit had been more forthcoming. :)
   / Is my bushhog too heavy #30
that will control the drop rate but not ur problem. I think the lever is vibrating down. My Myanmar ha. That problem an I have tighten the friction point.
KIDS DIRT BIKE (A53424)
KIDS DIRT BIKE...
2006 FONTAINE 48FT. FLATBED TRAILER (A55745)
2006 FONTAINE...
2007 Jeep Liberty SUV (A55853)
2007 Jeep Liberty...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
ASSORTED BINS (A55745)
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
