Is it worth it to buy the Echo CS-310?
   / Is it worth it to buy the Echo CS-310? #1
jkk04
PLYMOUTH CA
John Deere 410 backhoe, MF 30 industrial tractor, IH TD-14 dozer, New Holland TZ24DA
I just purchased echo CS- 310 chainsaw.
The reason to buy it is that it is much lighter than the Husqvarna 450 due to my age.
The weight is almost 3lb lighter than 450.
It makes me quite impressed after cutting some limbs, branches and dead oak trees.
Jkk
   / Is it worth it to buy the Echo CS-310? #2
I have 3 Echo's, the smallest and most used is the cs310. Nice saw, great price. I've been using it for 6 years.
   / Is it worth it to buy the Echo CS-310? #3
I have two Stihls. A big one - a small one. After hours of use they get heavy. The little/light one is so I don't accidentally cut off my toes.
   / Is it worth it to buy the Echo CS-310? #4
I don't have a pig in there race , however in the past I have purchased a couple saws here . I try to buy local but when theres a big difference in prices I order online .
Shindaiwa/ Echo for most part the same , just different colors and model #'s . They carry huge inventory .
   / Is it worth it to buy the Echo CS-310? #5
I bought one a couple of years ago for around the home pruning. Nice little saw.
   / Is it worth it to buy the Echo CS-310? #6
I bought a Stihl MS 261 a couple of years ago. It one of their smaller pro saws, I could have bought a larger farm and ranch saw for a little less money that would have had a little more power. It would have weighed 2 pounds more. My point is 2 pounds is a lot of weight difference in a saw.
Yes! Even a 1lb difference is a lot for a long period of cutting..
It was featherlight when I cut some trees yesterday because there was almost a 3lb difference between this saw and Husqvarna 450..
Unfortunately I didn't know the Echo 3510 is much better than the CS-310 according to a professional arborist.
The weight is 0.2 heavier and little more expenses but a lot of improvement.
I will consider buying it next time for sure.
Jkk
   / Is it worth it to buy the Echo CS-310? #8
Don't have a 310. Sometimes I wouldn't mind something smaller though. The 18" cs400 works for about everything. Something smaller to keep in my toolbox would work.
I like echos also.
I like echos also.
I am still a Husqvarna chainsaw fan 😄😄😄
The echo CS-400 is almost the same as the Husqvarna 440e that I used to have.
I still have Husqvarna 450 for cutting big trees that I cut couple days ago..
jkk
   / Is it worth it to buy the Echo CS-310? #10
This! My wrists, elbows, shoulders, can’t take it like they used to. I use the topping saw more than anything. I’m just very strict about never one-handing it. The electric gets a lot of use too, especially when I’m using the wood chipper. The little Stihl and the Kobalt can use the same chains so that keeps it simple. The bigger Stihl has the easy pull start, also a big plus for old arms. Serious point about toes BTW, I wear kevlar hard toed boots when I’m sawing.
KUBOTA L4240 TRACTOR (A57192)
KUBOTA L4240...
2009 Pierce 105ft. Quint Ladder T/A Fire Truck (A53422)
2009 Pierce 105ft...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
2007 International 4300 Dump Truck (A51692)
2007 International...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
