Is anyone else having lots of problems with an 1850?
   / Is anyone else having lots of problems with an 1850? #91
I've been learning the limits of my PT. I've found that it's easy to exceed them, but if I go a little easy I can keep my machine running a lot longer between repair stops. Tires are a good example -- I have the standard often-go-flat problems, but they're mostly due to crazy sideways slides down steep hills. If I avoid those maneuvers, the tires tend to stay inflated longer.
Same deal with overheating -- it's easy to run that machine beyond it's limit (90 degree tall-weeds mowing on a hilly open field). In a way, it's a design problem, but in a way it's just too easy to do certain things that push the machine too far. If I back off any of the variables (mow on cooler days, go slower through weeds, take it a little slower) things seem to go a lot better.
We've just been shuttling mulch across level yards with it lately. Before that mowing a monthly cut on about 20 degree hillside. Theres only one really steep dam side I mow twice yearly, and I raise the bh up and mow it twice...believe me I try to baby all my equipment.
Well , unfortunately, I spoke too soon. Its still leaking. I think its the pressure relief box assembly, the hyd. pressure is running too high; and probably causing more leaks.
I ordered a $50.00 blacklight/flashlight, supposed to be in today, but it looks like its leaking around that same canister unit, and the box on the frame rail which has given so much trouble.
I'm going to remove the box, and take it to a hydraulics rebuilder here..about an hours drive; see if they can rebuild it. I'm thinking the cyclinder might have to be honed out in addition to new seals.
Each time the box goes south, the pressure runs too high.
   / Is anyone else having lots of problems with an 1850? #94
It sounds like Power Trac needs to step up to the plate!
Hey! POWER TRAC! Don't act like your not listening...it is almost 2007, start the new year off right, do the right thing and step up to plate like a man (and good business) with AltavistaLawn.
Man-o-man, sometimes you just have to YELL sometimes ;~)
{hope this helps AltavistaLawn...hey it can't hurt}
Well, two years later ,and I'm still fighting it.
It might be down for the count, this time. The hyd motor is bad; it won't move, or operate any of the hydraulics. The hyd motor is only producing 150psi, and should be between 300 and 400psi.
Its still hard to believe I'm the only one having all this trouble with this model.
   / Is anyone else having lots of problems with an 1850? #96
wow, quite a thread...don't own one but what a nightmare you have on your hands, I dont think lemon laws cover AG machines but I sure would have considered it.
   / Is anyone else having lots of problems with an 1850? #97
so far so good for me. I think Ken would agree as well. My issues are related to age and abuse prior to my ownership.
I am bumming you are having issues....
   / Is anyone else having lots of problems with an 1850? #98
Well, it's been a couple of months...what has been the outcome of this last event?
Its parked under the carport next to the shop. I've been renting a skid steer. I don't see pouring another 5 to 6 thousand into it now, I'll fix it over the winter and sell it for whatever I can get for it.
   / Is anyone else having lots of problems with an 1850? #100
did you end up selling your 1850? Despite the troubles described, I'm considering one for mowing our steep acerage.
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
2014 LOAD KING BELLY DUMP TRAILER (A58214)
2014 LOAD KING...
Adams Tender / Magnolia Trailer (A56438)
Adams Tender /...
