Is altitude a problem?
/ Is altitude a problem? #21
I suppose that's the reason you don't see diesel powered piston engine aircraft although I believe I did read that, I'm thinking Honda, is working with a diesel aircraft engine. That would be interesting.
Just looked it up, it's DeltaHawk that has the diesel aircraft engine, Honda has jet engine for business class.
/ Is altitude a problem? #22
</font><font color="blue" class="small">( Is your 790 direct or indirect injection? )</font>
Yanmar 3TNE84 - Direct Injection-Self Bleeding (thankfully...) with a standard Manifold Air Heater, why?
BTW - Doesn't air get denser as it get colder anyway (molecules get closer together)?
/ Is altitude a problem? #23
</font><font color="blue" class="small">( I suppose that's the reason you don't see diesel powered piston engine aircraft although I believe I did read that, I'm thinking Honda, is working with a diesel aircraft engine. That would be interesting.
Just looked it up, it's DeltaHawk that has the diesel aircraft engine, Honda has jet engine for business class. )</font>
Theilert and SMA also make Deisel aircraft engines. Not many of then in the USA yet, but they're getting there.
The Deltahwk Diesel aircraft engines are turbocharged. I'm not sure about the others, but wouldn't be surprised if they are as well.
John Mc
2015 ARMOR LITE TRAILER (A67714)
2015 ARMOR LITE...
2015 Peterbilt 320 Roll-Off Truck (A66736)
2015 Peterbilt 320...
2023 JOHN DEERE 160P EXCAVATOR (A65056)
2023 JOHN DEERE...
2002 Mack (A64911)
2002 Mack (A64911)
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
PALLET OF SUMP PUMPS (A68842)
PALLET OF SUMP...
