Is all hydro fluid created equal
/ Is all hydro fluid created equal #1
Tomtint
Elite Member
Boston
L3700SU
The reason I ask, is because I have a power angle plow that I use on my skidsteer. ( Cat 246 ) The fluid is used to angle the blade left and right. I'm putting a 3rd function on my tractor and the blade could be used on that as well. At this point there is some fluid in the Pistons and lines of the plow from previous use on the skid. Obviously it will end up in the tractors system if hooked up and visa versa.
/ Is all hydro fluid created equal #2
Nope,it may be similar or compatible , but equal depends on additives and manufacturing process.
/ Is all hydro fluid created equal #3
Mixing a small amount of the old fluid will not have a detrimental effect on your machine. It will blend with the new and function fine. The larger the capacity of your hyd. system the less the effect. When you change fluid type (dino to syn.) some of the dino is still in the lines and blends with the syn.
/ Is all hydro fluid created equal #4
as said. sharing implements will generally 'top off' your fluid with other fluid.
for this reason I run utf in all my 'straight hyd oil' implements just so if they are swapped.. at least it is utf mixing in .
/ Is all hydro fluid created equal #5
No way to avoid mixing. I briefly thought about this when I changed the fluid in my M9540 and replaced it with high dollar SUDT2. Then immediately "contaminated" it with the old oil contained in each of my hydraulic attachments. :)
/ Is all hydro fluid created equal #6
I wouldn't worry about such a small quantity of fluid causing any problems. In theory it might lower the spec of the tractor's fluid a tiny amount, but it's hard to imagine that ever causing a problem.
Thanks all.
New Landhonor LHR-COA200,  200lb Cast Iron Anvil (A62679)
New Landhonor...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2005 Butler pole trailer (A62679)
2005 Butler pole...
78in. Skid Steer Bucket (A65640)
78in. Skid Steer...
3ft Teakwood Cowboy (A65583)
3ft Teakwood...
2012 INTERNATIONAL DURASTAR 4300 BUCKET TRUCK (A65643)
2012 INTERNATIONAL...
