Rotary Cutter Is a stump jumper needed for a 4-foot brush hog?
   / Is a stump jumper needed for a 4-foot brush hog? #11
The stump jumper is a misleading name that has nothing to do with stumps. It provided the place to attach the blades so they can bounce or flex when they hit something hard, or get overwhelmed. It provides a pivot point while the blades are spinning.
Most common stump jumpers are round disks, but Rhino has a design that is shaped like a dog bone that they say is better. If I had the money, I would of bought Rhino. I think they have a lot of features that are better then other brands.
The smaller mower will allow you to cut thicker material, but once you cut it, it will take a lot longer to maintain it. In my opinion, it is better to get as big a mower as you can, and then go super, extra slow the first time you mow. Set the deck as high as you can to knock everything down and then go over it another day to get it shorter.
Once you have the land under control, you will be very happy to have the bigger mower to maintain it and keep it under control.
   / Is a stump jumper needed for a 4-foot brush hog? #12
Interesting comment. The stump jumper pans on both my Landpride's are bowl shaped, not flat and yes the slasher blades mount to the pans and of course a PITA to change out with nothing less than a 3/4 drive impact and stout impact sockets. Landpride was thoughtful enough to have an access port on the top of the deck to access the bolts and nuts.
   / Is a stump jumper needed for a 4-foot brush hog? #13
Isn't the some sort of ratio recommended for horse power to diameter of brush hog, .. Something like 1 foot of cutter for every 5 HP of tractor.....
   / Is a stump jumper needed for a 4-foot brush hog? #15
I think that's accurate, but I've also found that if you are maintaining existing pasture and you don't let it get too tall, you don't need anywhere near as much HP as you do when you are cutting it for the first time after years of letting it go.
   / Is a stump jumper needed for a 4-foot brush hog? #16
Agreed! Mowing this with a 33hp engine and 6' LandPride bush hog can bog her down at times. If I mow monthly, it's not much of a challenge.
   / Is a stump jumper needed for a 4-foot brush hog? #17
I think I’m ok on lift capacity. Was more worried about whether a 25hp tractor has enough power to not get bogged down with a 5 footer.
Nothing says you must use the full width of a 5' cutter in heavy stuff.
   / Is a stump jumper needed for a 4-foot brush hog? #18
I mow a hilly rough 6 acre field, lawn and a couple of miles of trails with a 4 foot brush hog with a stump jumper hub.
I generally mow with a 19hp iseki/bolens diesel. Weight about 2200 without weights or deck.
Weight of the mower is only a problem when trying to turn on a hill with the smaller tractor. I built a box from half inch steel for the front of it and carry steel and lead weights. Still if it gets slipping on an uphill, lifting the the mower to gain traction is a problem in that it can wheelie. I have learned to avoid maneuvers which cause lack of steering ability.
   / Is a stump jumper needed for a 4-foot brush hog? #19
Yep !! And my stump jumper(howse 4 ft) is dinner plate shaped but still uses a TEE shaped shaft that the blades attach to. The stump jumper plate is thin and would never support blades by itself. I always assumed they were always built this way.
   / Is a stump jumper needed for a 4-foot brush hog? #20
General advise is, avoid turning uphill with above ground implements.
LOT: Assortment of PVC Pipe (A59076)
LOT: Assortment of...
2018 Chevrolet Equinox SUV (A56859)
2018 Chevrolet...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56435)
2002 Chevrolet...
2010 New Holland TD5050 95HP 4WD Agricultural Tractor w/ Bush Hog 2610 10ft. Rotary Mower Attachm... (A55973)
2010 New Holland...
1985 Allmand Max Lite III LD30-3CE S/A Towable Light Tower (A55973)
1985 Allmand Max...
2013 Wanco WTSP Folding Solar S/A Towable Arrow Board (A55973)
2013 Wanco WTSP...
