Is 50 HP really 50 HP?
   / Is 50 HP really 50 HP? #11
I That is, "IF" you want to use the tractor for a tractor and not a glorified lawn mower... lol SR
I hardly ever use the PTO on my tractor. I bought a B7100 to do my mowing, so now the PTO on the L3240 never gets used. I work my tractor hard, much harder than the average TBN member. My primary use is the loader and a distant second is the backhoe. My tractor has 715 hours and I have used the PTO for less than 20 of them. How does this make it a glorified lawn mowers?
   / Is 50 HP really 50 HP? #12
When I bought my 1720 the literature gave the gross hp as 27+- and the pto hp as 23.5.
Kinda hard for them to get away with falsely rating the pto higher than actual because it can easily be checked, also many people use the pto hp to choose a tractor.
90cummins
   / Is 50 HP really 50 HP? #13
Respectfully, I think you might be missing his point. The poster means the pto horsepower rating better represents the horsepower that is available to the Pto, or the pulling wheels, hydro pump, etc..; this is a better measure of the tractor's available power than measuring the engine under ideal conditions on a bench test.
   / Is 50 HP really 50 HP? #14
Example: My 5075E is sold as a 75hp tractor (engine, under who knows what ideal test conditions) , but put that engine in the tractor and it can only deliver about 64 hp to the pto (and I assume the tires too) according to Nebraska tests.
Drawbar horsepower is another piece of the pie particularly in ag tractors and takes into account transmission losses. I believe the Nebraska Test also takes tractive efficiency into account.
   / Is 50 HP really 50 HP? #16
The engine would deliver full power to PTO but not at 540 rpm. The PTO speed is set to about best torque and lowest fuel consumption engine rpm while maximum power is delivered at much higher rpm.
   / Is 50 HP really 50 HP? #17
Probably has been discussed here previously but wondering about the honesty of horsepower on new tractors. New models of agricultural tractors are normally run through the Nebraska Test to verify the advertised horsepower and pulling power. Is there anything like this for compact tractors?
Perhaps the new tractors have Volkswagen software that ups the fuel for the Nebraska Test?
Compact tractors are pretty light as tractors go. It doesn't take a huge power reserve to get the wheels spinning, and if pulling power is a priority, a farm utility tractor will be much the better choice vs. a compact. So horsepower is usually ample for getting around with most compact tractors, but what is important is getting adequate power at the pto for the implements that will be run, and having adequate power for the size of the tractor.
Regarding claimed vs. true horsepower, there are a few tractor brands made by companies that are also in the business of making and selling engines for industrial applications. To stay in that business, the products sold (i.e. engines), pretty much have to perform according to their rated specs. Since the engines going into their compact tractors are typically versions of their industrial powerplants, it's not hard to find performance information concerning the bare engine and compare it to what is claimed in the tractor sales literature. Any tractor marketing hanky-panky would be embarrassingly obvious.
Other tractor manufacturers may not build their own engines, but source them from a reputable engine manufacturer, whose engines have performance characterisitic that are similarly well-documented.
   / Is 50 HP really 50 HP? #18
HP is HP. Don't matter if it is gas, diesel, steam, electric, etc. Work done in a given time will be the same, if HP is the same.
As to the question, in today's soceity and with small engine makers just getting sued, and the fact that anyone can dyno their tractor, I don't think the MFGs are gonna lie about the numbers.
   / Is 50 HP really 50 HP? #19
No,, not according to Tractordata.com that references Nebraska Tests. 64hp is full power, 62.8 hp at rated PTO speed. All this for a "75"hp tractor,
   / Is 50 HP really 50 HP? #20
There needs to be more independent tractor tests as the Nebraska Power Tests.
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
Polaris Side by Side (A50324)
Polaris Side by...
