Ipad app not working
/ Ipad app not working #31
Yes, I'm using Sifari right now on my iPad since the app has crashed. Right below the reply - where I am typing now - you should see a button that says "Go Advanced" once you select that button you should figure it out from there. Good luck.
/ Ipad app not working #32
Gary,
I tried that but it's the same.. When I try to upload a new file, I cannot select anything as they are greyed out. (choose file). I can select a currently uploaded file, but that's it...
/ Ipad app not working #33
Try this...select Go Advance, manage attachments (paper clip button), add files in upper right corner, choose file, locate your picture, then once you add it then you can select it, then post it. Many steps, yes but that is how the site is designed.
/ Ipad app not working #34
Thats my issue, the "choos file" button I greyed out. I cannot select it. I understand hoe to do it, I just can't. Do I need turn something on in the settings to give permission to loo in my files or something. I appreciate the help. Thanks.
/ Ipad app not working #35
hmm.. can you post a link from a hosted file?
/ Ipad app not working #36
I am having problems with my IPAD I can read the forum, but can not get to any of the functions on the right hand side of the window. Means I can not respond to any of the postings. So is live. Heck never thought of getting there via Safari!
Yup, exactly what I'm seeing. The right 1 1/2 to 2 inches is totally dead. Never thought of rotating it though. Posting on my laptop now. Does the rotation just move the non-functioning section somewhere else?
/ Ipad app not working #37
Yes, you can rotate the screen to access every function. The dead part is always the 1/6 of the screen by the home button. It's just such a pain to keep rotating, so i've stopped using it. I can't believe a fix is this hard or takes this long to make.
/ Ipad app not working #38
The problem is the developer may not even know there's a problem. Because of the problem, you can't notify the developer or at least I haven't been able to. Muhammad, can you help us here?
You don't have to keep rotating it. Just launch the app in the portrait position with your home button on the bottom and use it that way. It works normally without the buttons going dead. I prefer it in landscape but this is adequate. As far as the fix is concerned, I couldn't agree more. Ridiculous that its still broken. And I'm quite certain that the developer is aware of the issue.
Sent from my iPad using TractorByNet
/ Ipad app not working #40
Okay, I see how that works but what a poor solution.
2019 CATERPILLAR 420F2 IT BACKHOE (A59823)
2019 CATERPILLAR...
2015 Doosan 750CFM T/A Towable Air Compressor (A59228)
2015 Doosan 750CFM...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2007 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A62129)
2007 CATERPILLAR...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
YANMAR VIO55-6A EXCAVATOR (A59823)
YANMAR VIO55-6A...
