Ipad app not working
/ Ipad app not working #21
i use safari on my iphone...
/ Ipad app not working #22
I am on safari now and it is working fine, looks like this is the way to go.....Wayne
/ Ipad app not working #23
I like using the app on my IPAD but when I upgraded the app the left side of the screen doesn't work. Hopefully there is a fix soon.
I wouldn't hold your breath waiting. If you open and use the iPad app in portrait mode not landscape it works like its supposed to.
Sent from my iPad using TractorByNet
/ Ipad app not working #25
Lets get some answers on this. The app was far easier to use than the site itself. Seems like they would get this correct ASAP. I let the developer know but that was more than a week ago now.
/ Ipad app not working #26
We're at the mercy of the developer on this. We forward issues... sometimes there are quick fixes, other times not as quick.
/ Ipad app not working #27
Excellent and thank you. Like I said the iPad app is actually easier to use so for that reason I miss it.
/ Ipad app not working #28
I deleted the app on my IPAD then installed an older version of the app that was still on my PC from the last time I backed up my IPAD. So it is working again for me.
/ Ipad app not working #29
Anyone know how to add pictures from Safari? I can't seem to find anything that will let me.
/ Ipad app not working #30
/ Ipad app not working #31
Yes, I'm using Sifari right now on my iPad since the app has crashed. Right below the reply - where I am typing now - you should see a button that says "Go Advanced" once you select that button you should figure it out from there. Good luck.
/ Ipad app not working #32
Gary,
I tried that but it's the same.. When I try to upload a new file, I cannot select anything as they are greyed out. (choose file). I can select a currently uploaded file, but that's it...
/ Ipad app not working #33
Try this...select Go Advance, manage attachments (paper clip button), add files in upper right corner, choose file, locate your picture, then once you add it then you can select it, then post it. Many steps, yes but that is how the site is designed.
/ Ipad app not working #34
Thats my issue, the "choos file" button I greyed out. I cannot select it. I understand hoe to do it, I just can't. Do I need turn something on in the settings to give permission to loo in my files or something. I appreciate the help. Thanks.
/ Ipad app not working #35
hmm.. can you post a link from a hosted file?
/ Ipad app not working #36
I am having problems with my IPAD I can read the forum, but can not get to any of the functions on the right hand side of the window. Means I can not respond to any of the postings. So is live. Heck never thought of getting there via Safari!
Yup, exactly what I'm seeing. The right 1 1/2 to 2 inches is totally dead. Never thought of rotating it though. Posting on my laptop now. Does the rotation just move the non-functioning section somewhere else?
/ Ipad app not working #37
Yes, you can rotate the screen to access every function. The dead part is always the 1/6 of the screen by the home button. It's just such a pain to keep rotating, so i've stopped using it. I can't believe a fix is this hard or takes this long to make.
/ Ipad app not working #38
The problem is the developer may not even know there's a problem. Because of the problem, you can't notify the developer or at least I haven't been able to. Muhammad, can you help us here?
You don't have to keep rotating it. Just launch the app in the portrait position with your home button on the bottom and use it that way. It works normally without the buttons going dead. I prefer it in landscape but this is adequate. As far as the fix is concerned, I couldn't agree more. Ridiculous that its still broken. And I'm quite certain that the developer is aware of the issue.
/ Ipad app not working #40
Okay, I see how that works but what a poor solution.
2004 FRAC TANK 500BBL WHEELED (A68842)
2004 FRAC TANK...
2017 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A69167)
2017 FREIGHTLINER...
MAXEY PORTAPOTTY VAC TRAILER (A67714)
MAXEY PORTAPOTTY...
CHANDLER 500 BBL FRAC TANK (A67714)
CHANDLER 500 BBL...
2025 Precisions Provencal 22ft. 5th wheel Mobile Office/ Showroom Trailer (A64556)
2025 Precisions...
2008 Hummer H3 4x4 SUV (A66738)
2008 Hummer H3 4x4...
