Inverter
/ Inverter #1
daedong
South Australia
Can someone tell me what i can run with a moderfied sine wave inverter. Can i run a TV, CD player, or fluro lights?
/ Inverter #2
You should be able to run all of those. My home is "off the grid" and I used a modified sine wave inverter for many years to power everything except washer, dryer and well (ran a generator for them).
Sometimes (depending on inverter model) you can get buzzing or lines on a tv. I also had a "situation" with a compact fluorescent light and a cheap surround sound amplifier: they were only a few feet apart and when the light was turned on, it would make the amp do weird things. Finally got a better amp and the problem went away.
Currently I use that old inverter to power a jet pump for our water pressure, and two sine-wave inverters (one for lights and entertainment, the other for everything else including washer and dryer).
Oh (on edit) VIN: NICE HOUSEBOAT!!!
/ Inverter #3
I run a trace 2500 watt inverter conected to 8 trojan T105 batteries in my garage for those lights out moments.
If it lasts a long time I have a diesel 12 kw. gen set that runs the place & charges the batteries at the same time. /forums/images/graemlins/smirk.gif
Ern.
/ Inverter #4
I agree with the others.. a m/s/w inverter should be fine.
Soundguy
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A64194)
Paladin 12in...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
