Introduction
/ Introduction #1
LarryBledsoe
Magnolia, TX
Cub Cadet Zforce 50"
My Cub Cadet Zforce 50" is 5 years old and dealer states one of the transmission needs to be replaced at a cost of $900. The problem initially was the unit was started to veer to one side like it lost power on one side only. However, with a little working of the steering arms i was able to get it back to the garage. I let it cool and check transfluid. It was empty in the resevior but i found no leaks. I did some research and found it need full synthetic rotella 15W40. It seems to work fine for a week then wife was mowing and the belt idler on the deck locked up. Repaired that and then a loud noise was noticed and the idler on the transmission was failing. Just before, this i noticed the transmission was not operating correctly, but thought the idler was casuing slippage attributing to the transmission issue. So, replace transmission idler and transmission seemed to get worse. I did notice transmission fuild looked like a creamy muddy solution. but, gave up at that point and took it to the dealer. When I received the bad news.
But, after reading some of the older post on Zforce 50" i am thinking i may have incorrect fluid and possible dirt build up in my transmission. I am thinking I am going to try to remove the fluid and flush with new fluid and see if that makes a difference.
However, I am open to input to any other who may have a similar experience.
/ Introduction #2
Not able to help you on the transmission issue, but welcome to the forum from Oklahoma. You might post in the lawn and garden section and you may get some information there.
Ken
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
UNUSED WOLVERINE QC1-26-20G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
iDrive TDS-2010H...
