Introduction
/ Introduction #1
LarryBledsoe
Magnolia, TX
Cub Cadet Zforce 50"
My Cub Cadet Zforce 50" is 5 years old and dealer states one of the transmission needs to be replaced at a cost of $900. The problem initially was the unit was started to veer to one side like it lost power on one side only. However, with a little working of the steering arms i was able to get it back to the garage. I let it cool and check transfluid. It was empty in the resevior but i found no leaks. I did some research and found it need full synthetic rotella 15W40. It seems to work fine for a week then wife was mowing and the belt idler on the deck locked up. Repaired that and then a loud noise was noticed and the idler on the transmission was failing. Just before, this i noticed the transmission was not operating correctly, but thought the idler was casuing slippage attributing to the transmission issue. So, replace transmission idler and transmission seemed to get worse. I did notice transmission fuild looked like a creamy muddy solution. but, gave up at that point and took it to the dealer. When I received the bad news.
But, after reading some of the older post on Zforce 50" i am thinking i may have incorrect fluid and possible dirt build up in my transmission. I am thinking I am going to try to remove the fluid and flush with new fluid and see if that makes a difference.
However, I am open to input to any other who may have a similar experience.
/ Introduction #2
Not able to help you on the transmission issue, but welcome to the forum from Oklahoma. You might post in the lawn and garden section and you may get some information there.
Ken
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
2004 AMMANN AV33E Smooth Drum Roller (A61166)
2004 AMMANN AV33E...
Brent 420 Grain Cart (A63118)
Brent 420 Grain...
(INOP) JOHN DEERE 5055E TRACTOR (A62130)
(INOP) JOHN DEERE...
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A62131)
UNUSED WOLVERINE...
UNUSED REMOTE CONTROLLED DUMPER TRUCK (A62130)
UNUSED REMOTE...
