Interpreting PA Tie Down Regulations
/ Interpreting PA Tie Down Regulations #1
strum456
Platinum Member
Westmoreland County PA
Fords
I'm trying to interpret the tie down regs, as per the PA State Police Cargo Securement Brochure.
Found Here: https://www.psp.pa.gov/law-enforcem...rgo Securement Brochure - Rev. 12-26-2015.pdf
I copied and pasted the following:
The aggregate WLL of tiedowns must be at least
one-half the weight of the article or group of articles
and is the sum of:
1/2 the WLL of each tiedown that goes from an
anchor point on the vehicle to an anchor point
on an article of cargo.
1/2 the WLL of each tiedown that is attached to
an anchor point on the vehicle, passes through,
over, or around the article of cargo and is then
attached to an anchor point on the same side if
the vehicle
The WLL for each tiedown that goes from an
anchor point on the vehicle, through, over, or
around the article of cargo, and then attaches to
anchor point on the other side of the vehicle.
Here is what I gather from the above information:
1. Adding up the capacity of all tiedowns need only equal HALF the weight of your cargo.
2. If you tie with 4 chains and 4 binders, one from each corner, only HALF of each chain's capacity goes to the total "aggregate" that is needed to secure the load.
Say you have a 10000 pound load.
You would need a total capacity to secure only half of that ie. 5000 pounds between all chains and binders.
However, if you use one chain/binder in each corner, you may only count HALF of each chain's capacity towards that 5000 lbs. Meaning each of the 4 total chains would need a minimum working load limit of 2500 lbs. (Half of 2500 = 1250 x 4 = 5000).
What really doesn't make sense, is if you take a single chain the whole way a cross the cargo, then you count the chain's ENTIRE working load limit towards the total "aggregate". Given a 10000 lbs load, again, we only need capacity for half of that ie. 5000 lbs. It appears that you could secure the same 10000 lbs load with a single chain at each end running across the load, as long as the capacity of each chain is 2500 lbs or more. This seems like half the holding capacity as the first option to me.
The second question would be, how much of this even applies to a "farmer". How about a "private individual" (not for hire). Clearly, no matter who you are, if you're hauling something heavy, you should tie down your load properly. However, I just read in another thread that a lot of the DOT requirements are not applicable for "not for hire" applications. It seems that farming has its own rules with a lot of this stuff, (usually more lax than commercial applications).
/ Interpreting PA Tie Down Regulations #2
And like here, the "Anchor Point" could be some loop stuck on with a blob of snot from someones buzz box.
/ Interpreting PA Tie Down Regulations #3
Interesting.
I've done a lot of research on towing - what capacity is, how it's defined, etc. Got that covered.
Never looked into securing loads...haven't hauled much of any substance very far, until recently - a 900lb brush hog, brought a 300lb tiller 50 miles (it shook loose). Most i've tied down is motorycles, but you use their suspension to keep the hold downs tight. Harder to get tension on steel on steel and compressing tires.
/ Interpreting PA Tie Down Regulations #4
I have just about buckled commercially built utility trailers (single 3500# axle) by tying stuff down with chain and binders.
/ Interpreting PA Tie Down Regulations #5
I got used to non-wratchet straps with motocycles..put e-track in my cargo trailer and rarely have anything move wiht the 'friction' straps. I do have one big wratched for it - moved a few freezers and some furniture and wanted it to say put.
moving my tiller the two wratchet straps come off (Ohio has some of the worst roads on earth) but the friction strap stayed put and kept the tiller on.
/ Interpreting PA Tie Down Regulations #6
I towed a big 3PH wood chipper back from Minnesota Last year. I beg to differ about the worlds worst roads.
/ Interpreting PA Tie Down Regulations #7
For your 10,000# load:
With two chains @ 2500# apiece, going across the load, for 5000# total capacity, if one breaks, you only have 2500# capacity holding the load. That would not be allowed.
With four chains @ 2500# apiece, fixed to the load, if one breaks, you still have 7500# capacity holding the load. That's more than half of the 10,000#.
I agree, 4 chains are better than 2. Now, is that what the regulation says?
/ Interpreting PA Tie Down Regulations #9
Just remember; no matter about the law and/or whatever you do or do not do to comply; lose that load and you and your insurance will pay through the nose. It is still the driver's responsibility to secure his load, that cannot be transferred or delegated. I always do more than what is required for my own peace of mind. I figure if I can afford the tractor I can afford the proper tie down equipment. I have refused to drive a load my employer said "the gear you have is good enough"; if I use substandard equipment then I get to share in the liability. Cannot for the life of me figure why owners/drivers are always looking at going cheap or why a farmer would do less because he is allowed too. The life you save may be your own!!
Ron
/ Interpreting PA Tie Down Regulations #10
If I tied my backhoe down with four 6800 WILL chains and it weighs 16.5k what does that leave for the loader and boom? I’m pretty sure they have to be tied down but since my other chains far exceeded the requirements can I just throw a really cheap 400 pound rated strap over the boom and the loader?
/ Interpreting PA Tie Down Regulations #11
IMO WILL being equal to half the machine weight isn’t enough. By that requirement I could use four 1/4 grade 70 chains or four 2” straps to secure my backhoe and I wouldn’t trust either setup. I’m using four 6800 pound chains tightened with four 9500 pound binders and I made sure the chain hooks were heavy enough for the chain. Low grade hooks should be banned. I paid $5 each for certified grade 70 hooks rated 11k WILL. How much does a grade 30 death trap hook save?
/ Interpreting PA Tie Down Regulations #12
Another big problem I see is throwing straps across brush guards, over box blades and whatever else with no strap protectors. I recommend avoiding the practice of using only 2 straps. Using 4 an not contacting anything else really reduces fraying.
/ Interpreting PA Tie Down Regulations #13
My concern isn't the normal driving - but an emergency situation. Sure, 2 straps may hold it down, but if you gotta slam on your brakes or someone hits you, then is htat enough to keep it in place? Will the loader, hoe, attachments stay put as well?
I like to be sure it's held vertically, fore and aft and side to side, and take wind into consideration as well as distribution of load. Many seem to pay no attention - and I suppose they arrive alive. the trailer is supposed to sit level when you're ready to go...not tilted fore or aft, yet I see that all too often.
/ Interpreting PA Tie Down Regulations #14
If I tied my backhoe down with four 6800 WILL chains and it weighs 16.5k what does that leave for the loader and boom? I知 pretty sure they have to be tied down but since my other chains far exceeded the requirements can I just throw a really cheap 400 pound rated strap over the boom and the loader?
Read my post above.
Ron
/ Interpreting PA Tie Down Regulations #15
Read my post above.
Ron
If you are in a crash bad enough to separate the loader from the machine than the 400 pound strap vs the 10000 pound strap doesn’t make any difference.
Can anyone help with interpreting the PA regulations?
Common sense dictates that if using a single chain to span the cargo, said chain would need to have 2x the capacity than if using two separate chains. Am I correct in my interpretation that the PA regs. do not align with this logic?
/ Interpreting PA Tie Down Regulations #17
My impressions are as follows,
First, this rule only applies to the WLL of the tie downs, it does not appear to directly address the proper methods of tying down a load but it does tend to lead a person in that direction.
and is the sum of:
The above is just a general rule of thumb to be used and is pretty straight forward. Keep in mind, this rule applies to the overall load, not just one piece of the load. As an example, picture a tractor with a FEL and mower, that is three pieces. Yes they are all attached to each other but I suspect, under this rule, they will be viewed as three pieces. The WLL of the tie downs must be equal to at least one-half the weight of the overall load and is subject to the following refinements that apply to each piece of the load.
The above is a refinement of the general rule and applies to only one piece of the load, ie "an article of cargo". What I get out of it is, if you are cross chaining a load, the combined WLL of the tie downs must be at least equal to the weight of the load. To me this makes sense in that if I am hauling my tractor with 2 cross chains on both front and back and I have to hit the brakes hard, I don't want an inferior chain on one side in the back to break. If it did the tractor would possibly be jerked off the side by the other chain.
the vehicle
Same as above.
Using the tractor example above of the tractor, FEL and mower, this refinement would apply to the FEL and mower. The WLL of the tie down used for the FEL or mower must be equal to or exceed the weight of that item. To me that is pretty straight forward.
As an example, say I am hauling my tractor with the FEL and mower attached. The tractor weights 6,000 lbs, the FEL is another 1,500 lbs and the mower is another 1,000 lbs. bringing the total weight to 8,500 lbs. I use grade 70 5/16 chains so the combined WLL of the tie downs is roughly 16,000 lbs., which is well within limits for the overall load. Except, each item has to be tied down so for the FEL and mower I can use tie downs whose WLL is equal to the weight of only the item being tied down.
/ Interpreting PA Tie Down Regulations #18
I bought some more chains and binders. I got everything in the picture for under 270 shipped to my door all grade 70 chain and hooks. I didn’t realize how big a 1/2 slip hook is. I should have bought 3/8 slip hooks but for a dollar more I was thinking bigger is better. IMG_0431.JPGIMG_0432.JPG
/ Interpreting PA Tie Down Regulations #19
Yeah, I've seen guys drive off with a 40,000# excavator just sitting on the trailer, no tiedowns whatsoever, because he was "just going 1/2 mile". Well, nothing unforeseen happened, so he arrived uneventfully...
/ Interpreting PA Tie Down Regulations #20
I have a relative that dropped a Case 580 off of a trailer after he drove without chaining it down. It landed on it's side in the street and they had to bring in a crane to pick it up. He said he didn't have to go that far.... YIKES!
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
Detroit Diesel 3 Cylinder Power Unit (A64912)
Detroit Diesel 3...
2000 Hino (A64194)
2000 Hino (A64194)
2015 Audi A4 AWD Sedan (A61574)
2015 Audi A4 AWD...
2011 TORO SP5040 MOWER (A66091)
2011 TORO SP5040...
2009 CHEVROLET IMPALA 4 DOOR CAR (A66091)
2009 CHEVROLET...
