international 674 not going in to gear
   / international 674 not going in to gear #1
international674
ireland
internatinal 674
i started my 674 the other morning and when i put it in to reverse it didnt move. so i tried the rest of the ranges and found out low range wouldnt work as well. high range works perfect. any help on what this might be??
   / international 674 not going in to gear #2
It is common for the hi/lo/reverse linkage to jam when worn . Mine did it quite often as it had a loader , I cant remember without looking at it but you just have to tap the linkage in the right place with a hammer or something .
   / international 674 not going in to gear #5
When lever is in hi the tractor moves . Do it move aswell when in neutral ?
   / international 674 not going in to gear #9
First ! You have a quadrant with a slot fitted to that shaft sticking out of the gearbox where that bush was sticky . Do that quadrant rotates a lot ? That will mix-up your gears and be a indication of a broken roll pin ! Do that quadrant rotates a lot ?
2015 CATERPILLAR 272D2 SKID STEER (A52709)
2015 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 LandHonor RB-14-66W 66in Rock Bucket Skid Steer Attachment (A56857)
2025 LandHonor...
Metal Sunflower Spinner (A57454)
Metal Sunflower...
2005 Chevrolet Colorado Pickup Truck, VIN # 1GCDT146258224098 (A57453)
2005 Chevrolet...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
