international 674 not going in to gear
   / international 674 not going in to gear #1
international674
ireland
internatinal 674
i started my 674 the other morning and when i put it in to reverse it didnt move. so i tried the rest of the ranges and found out low range wouldnt work as well. high range works perfect. any help on what this might be??
   / international 674 not going in to gear #2
It is common for the hi/lo/reverse linkage to jam when worn . Mine did it quite often as it had a loader , I cant remember without looking at it but you just have to tap the linkage in the right place with a hammer or something .
   / international 674 not going in to gear #5
When lever is in hi the tractor moves . Do it move aswell when in neutral ?
   / international 674 not going in to gear #9
First ! You have a quadrant with a slot fitted to that shaft sticking out of the gearbox where that bush was sticky . Do that quadrant rotates a lot ? That will mix-up your gears and be a indication of a broken roll pin ! Do that quadrant rotates a lot ?
Pines 1400 Tubing Pipe Structural Bender (A59213)
Pines 1400 Tubing...
2017 Ford F-550 Crew Cab Enclosed Service Truck w/ Liftgate (A56858)
2017 Ford F-550...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
2017 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2015 Ford F-150 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
MASSEY FERGUSON 35 TRACTOR (A58374)
MASSEY FERGUSON 35...
