International 385 PTO problem
/ International 385 PTO problem #1
paintedhorse
ms
intl 385
I replaced the leaking hydraulic line going to my steering, and also changed the hydraulic/transmission oil, and now the PTO won't work at all. The steering and lift work fine. The mechanical linkage seems to be fine. The handbook states the PTO hydraulically egages the flywheel to turn the PTO, so I'm hoping the problem isn't too serious. Any ideas what the problem might be? Thanks.
/ International 385 PTO problem #2
I would keep working the lever for the PTO and see if there might be any air trapped inside. The air should purge itself after use.
I have seen loader take about 5 to 10 cycles to purge the air.
/ International 385 PTO problem #4
Check for dirt in your steeringreturnline where it enters the mcv body. If that checkvalve is not working your pto will also not working...remove the pipe and then the union and the cage ...spring ....poppet............poppet must slide free into the cage ........clean and refitt in correct order
2015 ISUZU NQR 4X2 DEBRIS TRUCK (A59911)
2015 ISUZU NQR 4X2...
2006 Snorkel AB50J 50ft 4x4 Articulating Boom Lift (A61572)
2006 Snorkel AB50J...
2010 FORD RANGER SINGLE CAB PICKUP TRUCK (A59912)
2010 FORD RANGER...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2017 Mercury SeaPro Outboard Boat Motor (A61574)
2017 Mercury...
CASE FLEX HEAD (A63291)
CASE FLEX HEAD...
