International 240 stalling out
/ International 240 stalling out #1
kmanfiremedic
Mt Orab Ohio
International 240 utility
My international 240 stalls when I use the 3- point hitch, it sometimes wants to stall when I am in 3rd gear it will move 4 or 5 feet and try to stall till i switch to 1st or 2nd gear. When I move it to 1st or 2nd gear it regains power. is it a alternator problem or hydraulic pump issue or just a transmission issue? someone please help!
/ International 240 stalling out #2
Will using the 3 pt hitch when setting still make it stall..?? This I could see being a hydraulic issue, but not for long. I'm thinking if it's building enough pressure to stall the tractor, it would take out the front seal on the pump, and put your hyd. oil in the crankcase. Pulled the dipstick on the engine lately..??
Or just using the 3 pt. hitch when in third gear make it stall?
If it starts on it's own from the get go, I can't really see it being an alternator problem. Something mechanical seem to be dragging it down.
Have you had the tractor long, or just get it. Reason I ask... Did it just start this, or was it like this, if you just got it. If you just got it, did you check the hyd. & trans fluids..??
Also wondering what the brakes are like on it. It almost sounds more like a brake issue with them dragging, and pulling the tractor down. If the braking ability to stop is poor, then something is wrong. Those twin disc brakes will stop in in a heartbeat if working properly. If the tractor has ever set out a lot, could be all full of rust and crap, have the brakes half set, and pulling it down. In 1rst and 2nd, it maybe has enough power to overcome the braking. There are 3, 7/8" ball bearings in the brake expander. That can get all rusty, and the ball bearings crudded up, and not work properly. There's only like 4-5 bolt to take out, and the whole unit comes off for easy service. Also if the return springs are rusted and broken, it will not allow the brakes to come back to the full release position.
If it were like a bearing on the mainshaft of the trans, I'd think by now you'd hear some sort of noise coming from that area.
I have a 240 Utility, but with Fast Hitch. Never had an issue like that, but the brakes do get a little grabby after going through the spring sweat we get here in Ohio, and the expanders must get a bit of rust on them.
Will the tractor coast if on an incline, hill etc., very easily, if in neutral, or just the clutch disengaged? It should...
Hard to diagnose over the internet with limited understanding of what's going on. But just for kicks, I'd pull the brake housings, and check inside. As mentioned, 4-5 bolts hold them on, and remove the adjusting nut. Maybe some persuasion with a rubber mallet, and it should come right off.
It ran fine when I bought it, the hydraulics seemed to hickup when lifting the hitch but other than that it ran like a top
TR 23 Trancher (A64127)
TR 23 Trancher...
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
2001 Kubota L3010 (A64126)
2001 Kubota L3010...
2008 Kaufman Wedge Trailer (A62613)
2008 Kaufman Wedge...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
