Intermittent Starting Issue
/ Intermittent Starting Issue #1
BJMaine
Westport, Maine
John Deere 950
'88 JD 950. Sometimes it starts right up, other times turn the key and get nothing but lights. I assume its either a safety switch issue or possibly a starter issue. Any thoughts or ideas would be greatly appreciated. Thanks!
/ Intermittent Starting Issue #2
Have you checked voltage at starter? Yes it could be a neutral start switch problem. Test NS switch with a test light or volt/ohm meter.
/ Intermittent Starting Issue #3
My JD750 will do this if the PTO lever isn't totally disengaged. Maybe I bump it getting on and off the tractor?
/ Intermittent Starting Issue #4
I have a 950, had the same problem. You will find you have two safety switches, one on the PTO to make sure you can't start engaged, and the other on the range shifter. Over time, the connectors got funky with intermentent contact and did the same thing. I cut off the connectors on both ends and used a butt splice to hook up the wires, no more problems. I cleaned them several times, but it always came back to the same problem. Removing the bad connectors and hard wiring solved the problem for good. The switches themselves seam to be reliable. Also, something to look for is the contacts inside the selonoid, these are rebuildable. The plunger is about $30 or so and has a copper washer attached to it. The contacts are less than $5 ea, you will need 2 of them. Replacing both gives you a new switch inside the selonoic. After disconnecting the battery, remove the 3 screws on the cover, remove the plunger, and look at the contacts. Sometimes you can just clean the contacts and you are good to go. Hope this helped,
Chris
2018 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 INTERNATIONAL...
(10) New CATERPILLAR Keys (A65579)
(10) New...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
2026 Electric Tricycle (A64194)
2026 Electric...
1983 John Deere 2940 Tractor (A62613)
1983 John Deere...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
