Intermittent cut out problem
/ Intermittent cut out problem #1
rnbrn21
Honeoye Falls, NY
Kubota BX24
I've had an intermittent cut out problem for a while and finally decided to ask for comments. Every once in a while, maybe 1 out of 10 times when I go from forward to reverse on my BX24 the tractor dies for a split second and comes right back. It's not just a cold weather problem as it was doing it this past summer too. It is only when I change direction into reverse never from reverse to forward. Any ideas?
/ Intermittent cut out problem #2
Is it possible your body is rocking a bit forward, lifting the seat back ever so slightly? The seat switch was really touchy on mine before I made an alteration. I stuck on a thin adhesive backed pad where the switch touched.
/ Intermittent cut out problem #3
I had a similar problem with my BX-25. I took the tractor to my dealer. A mechanic got up on the trailer and adjusted one of the safety switches with a screw driver. I didn't even have to take the tractor off the trailer. It took him about 5-minutes and there was no charge to me. You got to like the dealer down there in Franklin.
1992 Fontaine Trailer 44ft (A62679)
1992 Fontaine...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
2012 Great Dane 53' Van Trailer (A66285)
2012 Great Dane...
2022 EZ-GO ELITE...
429888 (A61165)
429888 (A61165)
