Interesting Mower
/ Interesting Mower #1
QRTRHRS
Elite Member
The Bluegrass State
None at this time.
Just saw a pop up ad for an Altoz mower. If the tracks limit the sliding associated with a ZTR, this company may be onto something?
I have a lot of slopes on my property that will take your breath away. I have thought about trying those lugged tires like Dixie Chopper used on my Scag.
/ Interesting Mower #2
They’ve been around for a while now. I didn’t have any dealers with any inventory within 200 miles of my location so I had to pass on their product when I was shopping for a good hillside mower for my property.
I ended up purchasing a Cub Cadet Pro Z 560S KW commercial ZTR with 4-wheel steering and never looked back.
Mike
/ Interesting Mower #3
Yes I'm sure that has a benefit if you're on hilly/wet areas, but it's not for me. My place is flat and I tear up the turf enough, doing the "zero turn"s with wheels.
/ Interesting Mower #4
My son runs 2 where he works. He says they are beasts!
You do have to turn a little more careful with the tracks, but they actually put down less ground pressure than wheels so you can mow when the subsoil is "wetter" (hope that makes sense).
/ Interesting Mower #5
Just as a sidebar; Make sure your tires are inflated to MIP (Maximum Inflation Pressure). My Bad Boy was doing the same thing and discovered the tires were low. Inflating them helped tremendously. You can still tear up grass if you're too aggressive in the turns. Reversing the inside wheel instead of stopping helps.
/ Interesting Mower #6
What did you decide in the end? I’ve been in a similar spot with slopes, and after trying a few options, I ended up going with a Grasshopper Mower. The zero-turn handling is great, and it actually manages slopes pretty well without feeling unstable. I considered the Altoz tracks too, and they do look promising for really steep terrain, but for me, the Grasshopper struck a good balance between speed, maneuverability, and comfort.
